I recently purchased a Powersoft Digam 5000 second hand for a nice price. It's rated at 750W/8 Ohms RMS/Channel and stable to 2 Ohms (2050W/channel). So it should be able to power up to 10 T48's
Anyhow, one of its 'features' is a "clip limiter and permanent signal compressor". What this does, is protect the speakers from excessive clipping. I can say that it works. If you drive the amp hard (red LED lights up), it gradually decreases it's gain until you're in the 'safe zone'. But the detection of a too large signal is a little odd: sine(like) waveforms are compressed/decreased the most. If driven with a pure sine, the amp turns down its gain until it puts out no more than 30~35Vrms
The facts:
750W/8 Ohms ~ 77 volts
450W/8 Ohms ~ 60 volts (= max voltage for Eminence 3015LF)
Peak 'music' power 3015LF: 900W ~ 85V
35 volts ~ 150W/8 Ohms (= quite overdone 'protection' if you ask me, but safe for a 3015LF, that's for sure)
The thing is, this Digam 5000 can output 750W shortly during bassdrum peaks and doesn't compress the sound (this is what Powersoft intended for these amps, amplify music, not sinewaves). Now would it be safe to rely on the clip limiter/compressor of the amp when powering a T48-3015LF loaded? Or posed in a different way: can the 3015LF take 750 watts of music power (not sine waves) when mounted in a T48? Or: is 60V the limit for linear excursion of the cone or for Xmech?
I have a DCX2496 and set the limiter for 60V output (quite difficult when the amp starts decreasing its gain due to the sine wave signal after only a few seconds). If I switch the limiter off, I hear quite some more power in the kick, while any continuous sinelike wave gets compressed/turned down. It seems to sound cleaner without the DCX2496-limiter...
I find it quite difficult to write down exactly what I am tryin to say, so please bear with me. If something needs more explanation, please ask!
