Subs stacked so the mouths were on top of each other. V plate not yet made.
Tops: POS 15's and piezo direct radiators. No idea of what they are as can't find any info. Stacked so that cabs were 4' above ground and piezo to piezo. More on that a little later.
CD/MP3 player to Soundcraft Spirit Live 16/2 all run up to just below clip on channel and outputs.
Into a DCX2496. DCX set to -6dB on the limiter on sub output initially. Crossover set to 120Hz. HP 45Hz on subs as per plans.
Out to Jands 920 amplifier, one channel will drive subs, the other tops. Not connected initially.
60Hz sine wave run through system. Peak voltage in the sub side 33.9V. Can't do much better when the target is 35V, so limiter left alone.
Levels dropped on the masters to -10dB
Subs and tops connected.
Music played. Desk Channel EQ tweaked. Multimeter on the subs output unchanged when run up to 0dB briefly.
Oh deary me!
Turned down tops pot on amp from max to 1 o'clock. Better balance.
SWMBO on hand, as she wanted to be...
Back up to 0dB on the masters.
Chest pounding bass, I mean awesome chest pounding bass. This is in the garage, both garage doors open (either end).
She tells me to "turn it off for a tick"
"That's what it was like at AC/DC" says she. Uh huh, we were at the other end of the stadium from the PA at that one.
"Play some real music" (she's into american country) says she. Keith Urban will cover that...
Cranked. Awesome. These are not premium driver 10's? C'mon.
My turn, whack in the reference CD, give that a whirl. Straight to Danny Gatton's 13 women.
OMFG.
Each song after that had different highlights.
Stoked.
Need to check the cabs over after I strap down some speaker wire inside etc,
Build a V plate, try again. So tempted to do 2 more immediately, but tops and monitors beckon first.
Review ended.
Since added a DEQ2496 to the rack.
Will get a reference mike and run rig outdoors with RTA to see where the POS tops fall off the perch on the bottom end to see if I can cross lower, until/when the DR's are done. And system tune with DEQ also.
Community feedback 3 days later (they live half a mile/600m away).
Hey all that music you were playing the other day sounded fantastic, full, warm. Not harsh. Clear as a bell. What were you using?
