Table Tuba!
Posted: Wed Apr 04, 2012 6:16 am
Sooo, I had a MCM #55-2421 lying around I had intended to put it in an autotuba, but I found the JBL GTO 804 cheap so I used that instead.. Which has amazed me heaps. Everyone compliments the sound in my car - nice!
So after pondering this for a couple of months I decided it was time to use the MCM for a table tuba as i'm starting to build up a decent home theater! I'm on a tight budget, so first things first - im going to build the sub first and replace the sub in my Philips 5.1 sound system.. The front speakers is not horrible but the sub is, so thats where im starting for now. The built in sub-amp in the receiver is good for a 15-20v, so I should be able to shake my building a little
I have a few days off this week, and I can really feel my builds picking up speed and precision - i'm getting a lot better!
Day one:
Drawing where all the panels are going. I had 2 sheets of 12mm radiata pine preripped at my local lumberyard as i didnt have means to transport it otherwise.. Good thing is that the panels are all 100% similar width
Panel 1 going on!
Trial fitting the driver - its a perfect fit!
Trial fitting
Baffle, panel 2, 3 and 4 done.. I love how fast panels are to mount when using the techniques described in the plans - i use a lot of scrap plywood pieces to get everything square!
Everything is perfectly square!
Panel 6,7 and 8 came on and a horn is forming!
Panel 9 was the last panel I fit as it was getting dark.
When I cleaned up after I was kinda amazed at how much I had gotten done in 4 hours!
Day 2 next..
Day one:
Panel 1 going on!
Trial fitting
Day 2 next..
