Measure Mixer Output
Hey all,
My mixer output seems to be low to me. How would I measure that to see if it's doing what it's supposed to be?
Thanks!
Donny
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
- BrentEvans
Re: Measure Mixer Output
Use the same method you user to measure amps. 1k sine into a channel, gain it up until the channel is just below clip, turn up outputs until just below clip, measure pins 12-3 AC voltage. 1.7VAC would reference +4db over unity gain. More is fine, very much less than that would mean low output.
If you had an oscilloscope then you could actually see where it clips too. That would be the bees knees! I barrowed one from work to set up my system! Turns out that the red LED really does mean it's clipping. HU who knew?
OK...here's what I'm observing...
I'm sending a 1 K tone, the channel is soloed and channel fader and master faders are in what I believe are the unity gain positions (it's near the top and labeled "0" with a bolded horizontal line at that mark.) The multimeter is reading 1.26 -1.6 to keep the mixer lit up to +4. Clipping starts are 5.07 volts. What does all that mean?
Thanks!
Thanks!
Donny Collins
- BrentEvans
It means your mixer is doing exactly what it's supposed to do. 5v clip is quite common.
Circling back... why do you feel your mixer output is low?
Very cool Brent. Thanks for the affirmation.BrentEvans wrote:It means your mixer is doing exactly what it's supposed to do. 5v clip is quite common.
Donny Collins
- BrentEvans
Heh... you must have missed my edit.
What makes you think the mixer has low output? There must be something you've recognized as a potential symptom.
I think maybe I just need to run my amps with more sensitivity. Inputs going in are hot enough, channel faders are in the unity gain area. I usually have the main faders way up in the unity gain area too...it just feels like the mixer outs are not very hot when the faders are that high. The board meters around +4 or so at that point.BrentEvans wrote:It means your mixer is doing exactly what it's supposed to do. 5v clip is quite common.
Donny Collins
- BrentEvans
That's probably the answer. Gain structure can be a booger. Don't forget to reset your limiters if you didn't do it with amp gain maxed out to begin with.doncolga wrote: I think maybe I just need to run my amps with more sensitivity. Inputs going in are hot enough, channel faders are in the unity gain area. I usually have the main faders way up in the unity gain area too...it just feels like the mixer outs are not very hot when the faders are that high. The board meters around +4 or so at that point.
Yes...I set it with the sub amp wide open. Thank again man!BrentEvans wrote:That's probably the answer. Gain structure can be a booger. Don't forget to reset your limiters if you didn't do it with amp gain maxed out to begin with.doncolga wrote: I think maybe I just need to run my amps with more sensitivity. Inputs going in are hot enough, channel faders are in the unity gain area. I usually have the main faders way up in the unity gain area too...it just feels like the mixer outs are not very hot when the faders are that high. The board meters around +4 or so at that point.
Donny Collins
