Crown System Architect vs. Band Mangager
- BrentEvans
What's the difference? I'm going to be setting up some XTI's in an install later this week, and I'd like to use the best tool.
Re: Crown System Architect vs. Band Mangager
Band manager is all you need for your application. The "Full version of Sys Arch is a larger download and has built in presets for other devices that are in the crown family and or use HiQ net software as a controller. Example: XTI 4000 with JBL JRX 728 preset. The software usual auto detects hardware upon start.
Warning! be patient on first start of either program it is painfully slow. Once you are in it is pretty straight forward. Also be careful if you use the built in Pink noise generator. It bypasses all internal settings and follows attenuation of the amp.
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
- BrentEvans
will band manager update the firmware on the amps so they can have 8 eq points to use instead of 6, like system architect will?
Greg Plouvier
I prefer SA. You should update the firmware first anyway and SA does it for you. I've had problems with band manager detecting devices so I've always just used SA. Are you installing XTI2's or 00's? (Thanks for the CAD info by the way)
Greg Plouvier
- camrynekai
Same here. Been also using it wireless with great success.Greg Plouvier wrote:I prefer SA. You should update the firmware first anyway and SA does it for you. I've had problems with band manager detecting devices so I've always just used SA.
Facebook Page
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
4- OTop 12's W/melded array's
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- BrentEvans
The amps are xti1000s, the last of some old new stock.Greg Plouvier wrote:I prefer SA. You should update the firmware first anyway and SA does it for you. I've had problems with band manager detecting devices so I've always just used SA. Are you installing XTI2's or 00's? (Thanks for the CAD info by the way)
USB over wireless? What is your solution?camrynekai wrote:Same here. Been also using it wireless with great success.Greg Plouvier wrote:I prefer SA. You should update the firmware first anyway and SA does it for you. I've had problems with band manager detecting devices so I've always just used SA.
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
- camrynekai
I am using a Belkin wireless N router, IOGEAR USB Sharing Hub http://www.iogear.com/product/GUIP201/ and an every day USB 4 port hub so that I can work with more then one device. The IOGEAR has its own software that you need to run...but it has been flawless on everything I have thrown at it except USB-RS232 adapters...it just wont designate a com port for some reason.
Facebook Page
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
My herd of T48's
Cabs built
2- 29" Sla Pro's
1- Auto tuba ITW
- BrentEvans
Well... I burned 500mb of my data plan downloading System Architect. I'm quite impressed, this is not at all what I was expecting. It was actually quite pleasant to use. I'm not accustomed to using Q instead of Bandwidth on EQ, but the editable graphical display makes that a simple switch. Compared to Ashly Protea NE Software and Sabine Navigator, this is by far the easiest to use.
For those of you that have used it, is the interface the same if you're editing something like a DriveRack 260?
BE
BE
have to say I quite like System architect as well. I wish it was a *bit* more user friendly, and allowed the user to have multiple xover/eq/delay/limit windows open, and also have settings to insure they dont pop up over the top of other useful windows. Might check out band manager in the near future.
