TITAN48'S CORNER LOADED
Posted: Sat Mar 10, 2012 10:02 pm
by on1sony
Re: TITAN48'S CORNER LOADED
Posted: Sun Mar 11, 2012 8:42 pm
by loudsubz
i like the pink BBE DS
Posted: Wed Dec 04, 2013 11:53 am
by bradn7
are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
Posted: Wed Dec 04, 2013 3:34 pm
by Grant Bunter
bradn7 wrote:are you powering that with a QSC 2450 RMX? I ask because I want to make sure that my amp will be able to power them easily.
I'm not sure that the OP will be able to answer you.
I think he is no longer a forum member...
Posted: Wed Dec 04, 2013 7:56 pm
Here's how you do it.
1. Google QSC RMX2450
2. Follow a link and find out it's wattage rating at either 8 or 4 ohms - whichever you are going to be hanging on it.
3. Go here:
http://www.sengpielaudio.com/calculator-ohm.htm
4. Put in the ohms and the wattage. It will tell you the voltage output. If that is more than the plans call for as the voltage limit - you are good to go.....with your limiter hooked up, of course.
Posted: Wed Dec 04, 2013 8:35 pm
by bradn7
Thank you for that page.
Posted: Fri Dec 06, 2013 8:18 am
by escapemcp
Grant Bunter wrote:I'm not sure that the OP will be able to answer you.
So it FINALLY happened then???
(Sorry guys, out of the loop as I have been away for a few weeks (new job(=new speakers
Posted: Sun Dec 08, 2013 5:56 am
by Michael Murphy
I think it was just a ban.
