PV2600 powering Tuba 24
shawno
#1 Post by shawno »
Newbie with a set of RCF-310As for tops and a dual loaded Tuba 24 for lows, playing prerecorded top 40/house/hip hop.
Would a Peavey PV2600 amp with the Built-in 150 Hz/18 dB/oct crossover enabled be low enough for a Tuba 24, dual loaded with BP102 drivers?
Or should I just pull the trigger on a dcx2496 and disable the PV2600 crossover?
Re: PV2600 powering Tuba 24
shawno wrote:Newbie with a set of RCF-310As for tops and a dual loaded Tuba 24 for lows, playing prerecorded top 40/house/hip hop.
Subs should be crossed over at 100Hz or lower.
shawno
#3 Post by shawno »
Thank You sir !
I guess I'm shopping for a DCX2496 or something similar.
