Dcx 2496 question
djtrumptight
Dcx 2496 question
#1 Post by djtrumptight »
I was wondering if I could use an output from my dcx into my amp for my tops and use a summed signal output from the dcx into the other amp input to power my sub.my reason being that I want to raise the output gain on the summed signal to get more voltage to the sub.I dont like how the system sounds using the crossover in the xls 1500.
2 Autotuba's MCM 55 2421
8 T48's 24"wide 3015 LF
2 SLA HT systems
1 Table Tuba Dayton DCS 255-4
2 T 39's 20" wide 3012 LF
1 T-18 13" wide MCM 55 2421
2 SLA Pro's
Re: Dcx 2496 question
#2 Post by DJPhatman »
That is exactly what the DCX2496 is used for.
#3 Post by Gregory East »
That is what it's for...and phatman is dead right..
Q, how come you're building t39 and not slim T48?
#4 Post by Tom Smit »
That's how I did it....input to Input A,... summed out to, I choose, Output 5, .....tops are on Output 1.
djtrumptight
#5 Post by djtrumptight »
Ok,thanks fella's.I tried using the crossover in the XLS 1500 but i could only get about 22 volts to the T 39.Gregory i built the T 39 to use in low volume situations and small rooms,a comedy show i do once a month in particular.A T39 is short enough to fit in my 2011 Jeep Liberty replacing a EV S-181 sub i was using for the event.I built both cabs but only bought 1 driver.My next build is 2 new T-48's as well as rebuilding the 2 i already have.
2 SLA HT systems
2 SLA Pro's
