Dubwoofer's Tuba HT build
Dubwoofer
#1 Post by Dubwoofer »
I'm building a 24" wide THT as per the original plans, the only deviation being instead of PL premium I am using Gorilla glue. The material is 1/2" 9 ply cabinet grade baltic birch plywood. The Tuba will be loaded with a RSS390HF-4 driver.
In construction I have not had to use any jigs or guideboards except a long piece I screw down to align pieces with the lines on the first side.
In the beginning:
Woofer burn-in (I don't think I want to do this with it installed):
First panels:
A little jump:
So far so good...
spoogin
Re: Dubwoofer's Tuba HT build
#2 Post by spoogin »
Looking good, but why not use the PL? just curious
Dubwoofer
#3 Post by Dubwoofer »
spoogin wrote:Looking good, but why not use the PL? just curious
I already had a bunch of gorilla glue, so I didn't need to buy anything.
#4 Post by Radian »
Looks real nice. :D I hope it doesn't leak any..it'd be a shame. :fingers:
#5 Post by Bill Fitzmaurice »
Dubwoofer wrote: I already had a bunch of gorilla glue, so I didn't need to buy anything.
If Gorilla was a viable substitute it would say so in the plans. It has nowhere near the strength of PL. It may work OK, but if you have a leak where you can't reach it you're screwed.
Dubwoofer
#6 Post by Dubwoofer »
I thought gorilla glue was urethane based
If guess we'll see what happens. So far I don't have any visible gaps and my pieces are lining up perfectly. I caulked the woofer chamber for good measure and I'll finish fastening the sides with a brad nailer.
#7 Post by Bill Fitzmaurice »
It is, but it's not in the same league as PL.
Harley
#8 Post by Harley »
"Gorilla Glue" is a treacle-like glue and Bill is right, it's not the best to use in BFM cab construction.
Gorilla Grip Express on the other hand is a 100% expanding polyurethane and is the same leage as PL, but often gets called Gorilla Glue. PL has a colourant added as it's widely used in the construction industry in the USA, the colourant being a woody colour ( brownish )
http://www.holdfast.co.nz/pages/product ... psid=20075
#9 Post by Bill Fitzmaurice »
Harley wrote: Gorilla Grip Express on the other hand is a 100% expanding polyurethane and is the same leage as PL
That seems to be exclusive to NZ.
Dubwoofer
#10 Post by Dubwoofer »
I'm hoping to finish the cabinet this weekend. I have no school today so hopefully I can make some progress.
Dubwoofer
#11 Post by Dubwoofer »
The end is nigh...
No complaints about the gorilla glue.
88h88
#12 Post by 88h88 »
That looks like a mighty clean build due to the glue you've used. Be sure to double and triple check it for leaks before you put the side on.
Harley
#13 Post by Harley »
88h88 wrote: Be sure to double and triple check it for leaks before you put the side on.
+1
#14 Post by DJPhatman »
88h88 wrote:That looks like a mighty clean build due to the glue you've used. Be sure to double and triple check it for leaks before you put the side on.
+2
I would even caulk the side edges before you close it up. You won't be able to reach them once the second side is on.
Dubwoofer
#15 Post by Dubwoofer »
I'll caulk as much as I can before the side goes on. So far things look good...
