This is my first BFM build, and my first woodworking project in a long time, having built a coffee table some 17 years ago with a lot of help. I'm building 2x Jack 112 with no tweeters, for my bass playing habit. I hope that by posting the build here I can get some help and advice as I go and maybe encourage others who are sitting on the fence. I am not an expert, but I have read the plans quite a few times. I will probably still ask some dumb questions but that is what I am here for.
I have borrowed a lot of tools and am building the Jacks in my garage. The photo below shows the garage during the build at about the messiest it gets as I have to fit a car in at night and the laundry is out of shot to the right. I also like to be tidy
I'm using 12mm Italian Poplar for the build and this next photo shows my first cut, using a circular saw with a brand new 184mm, 60 tooth blade and a level as a fence/guide. That cut piece is for the bottom (lower right corner of the photo) and a side (top Left corner of the photo), the vent ducts and throat reflectors to come from the middle section. I marked/cut it like that cos I figured at least two parts would have a square corner! Moving right along, I have marked up the bottom as per the plans, made more cuts, marked up the baffle and cut it out using a jig saw.
