Nexo Sub
- Dave Non-Zero
Re: Nexo Sub
some kind of bandpass. 4th order? it has two chambers and large ports. They sound a bit waffley for me.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Re: Nexo Sub
Bandpass. Better than a direct radiator, but it's no horn.
UROK
Re: Nexo Sub
Thanks Dave.
Thanks Bill.
I will be looking up bandpass designs...
So no point boundary loading?
Dave, would you care to expand on "waffley"??
You mean like Melvyn Bragg???
Guy is now saying they don't have enough power to run 3 amps for 4 MAWS3s, 2 LS1200s, and a pair of monitors.
You guys reckon 220-240V should be ok to run those at moderate levels? (I think he's miscalculating based on the watts ratings of the drivers .)
With proper limiting should we be able to run that system off house power?
Oh for my rig to be complete!
Sorry. Learning tons here. Thanks for input.
Thanks Bill.
Re: Nexo Sub
Boundary loading works with all alignments.UROK wrote: So no point boundary loading?
- Dave Non-Zero
Re: Nexo Sub
They are tuned really low for club stuff, but they are just kinda...waffley.
try have them and ps15s in the local student union. I have compared them to t48s.
With 240v you can run a hell of a lot. I've run 8t48 and 4dr280 plus a t60 all from one plug with no problems many times.
240v is over 4kw rms, so you should be golden.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Re: Nexo Sub
Your house circuits must be a lot more capable than our normal ones. To be confident of drawing any more than 10A I'd need to run off separate circuits. I have run 4 T48 + tops off that no problem but it wasn't at full volume. The driver rated power power in the subs would be 1400W, add amp inefficiency @ 1400W and some more for the tops, must be close to ten amps at full tit.
Re: Nexo Sub
for house party, just unplug the dryer LOLDave Non-Zero wrote:240v is over 4kw rms, so you should be golden.
UROK
Re: Nexo Sub
Dude, that's closer to the truth than you expect! They are running four industrial fridges in there ATM!BoostFab wrote:for house party, just unplug the dryer LOLDave Non-Zero wrote:240v is over 4kw rms, so you should be golden.
wounded horse
Re: Nexo Sub
Mm, don't see this. If you give it a bit of legroom and stick to 12A max so you're a touch off tripping something 230 Volts X 12A = 2760 watts max. You'd want 17 amps or so to have 4kW.Dave Non-Zero wrote:kinda...waffley.
- Jon Barnhardt
Re: Nexo Sub
Typically 240v is 50 amps. Which would be 12k watts...
http://www.supercircuits.com/resources/ ... -Converter
Re: Nexo Sub
In the many places around the world where 240V is mainstream household supply it doesn't come out of the wall at 50A. Commercial installations running arc welders, huge A/C units etc, sure, but it likely won't have a standard plug outlet for a hairdryer or a hifi.Jon Barnhardt wrote:Typically 240v is 50 amps. Which would be 12k watts...
Re: Nexo Sub
Here the average 240V household wiring is fused at 16A, some 3800W.
Usually there is more than one socket on a single fuse. Older houses can have the entire house on 2 or 3 fuses.
- Jon Barnhardt
Re: Nexo Sub
I should have qualified that with here in the US...Gregory East wrote:In the many places around the world where 240V is mainstream household supply it doesn't come out of the wall at 50A. Commercial installations running arc welders, huge A/C units etc, sure, but it likely won't have a standard plug outlet for a hairdryer or a hifi.Jon Barnhardt wrote:Typically 240v is 50 amps. Which would be 12k watts...
Re: Nexo Sub
OP is in BJ PRC, Beijing, People's Republic of China
