Duratex vs. Line-X (again).
BrentEvans
#1 Post by BrentEvans »
Ok, so Mythbusters did some tests of Line-X, and the stuff stands up pretty darn well. Like.... to C4.
What piqued my interest is that the Line-X installer referred to it as an elastometric product. IIRC, that's what Duratex is as well... and I know my Duratexed cabs aren't going to stand up to a C4 blast.
So... what's the difference? A buddy of mine does Line-X on his cabs, and I bought one of his wedges (cabinet builder installed the baffle upside down, so I got it for a song) and the Line-X is definently superior in hardness and durability to the Duratex, but the Duratex on my cabs is a thinner coat.... if it was built up would it be the same durability? Is the cost worth it?
Dan30
Re: Duratex vs. Line-X (again).
#2 Post by Dan30 »
I think this show has ran out of ideas. lol
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
BrentEvans
#3 Post by BrentEvans »
Dan30 wrote:I think this show has ran out of ideas. lol
Heh... gratuitous explosions and other various destruction make up for it. :chainsaw:
Dan30
#4 Post by Dan30 »
I just finished the episode. (with some skimming) and that bedliner is really impressive. I wonder how many coats they applied for the wall experiment.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
BrentEvans
#5 Post by BrentEvans »
I think they said 1/8". That's a standard application, I believe.
#6 Post by DJPhatman »
+1,000,000,000,000,000,000,000,000!!!!!!!!!!!!
But, I will still use Duratex on my speaker cabinets!
camrynekai
#7 Post by camrynekai »
My T48's are Line-X'ed....it was a very expensive venture, but worth EVERY penny. It is applied with two coats...a smooth one that is just over 1/16 of an inch and then they do a splatter coat that is also a 1/16 of an inch. Basically, its a molten plastic and as durable as you can get. For my tops, DuraTex is plenty good but for my subs that get tossed around Line-X is bullet proof.
Facebook Page
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
4- OTop 12's W/melded array's
2- 29" Sla Pro's
1- Auto tuba ITW
BoostFab
#8 Post by BoostFab »
I did see that MythBuster episode, I was going to post here about it, but forgot to. I'm pretty impressed by the C4 blast protection, not like your cab ever see that pressure. It's too expensive....
el_ingeniero
#9 Post by el_ingeniero »
camrynekai wrote:My T48's are Line-X'ed....it was a very expensive venture, but worth EVERY penny. It is applied with two coats...a smooth one that is just over 1/16 of an inch and then they do a splatter coat that is also a 1/16 of an inch. Basically, its a molten plastic and as durable as you can get. For my tops, DuraTex is plenty good but for my subs that get tossed around Line-X is bullet proof.
Can you give us a rough idea what it costs to get a cab line-x'ed?
