Dremmel Trio or Alternative
doncolga
#1 Post by doncolga »
Hey,
For cutting out driver holes and access panels with 5-7 ply 1/2 inch Baltic Burch, should I consider the Dremmel Trio? Anything that may work better? Before I used a regular jig saw. While it did work, the finished cut wasn't the cleanest in the world. Also, my plunge cutting for the T30 access panels left a little to be desired.
Maybe I should save that money and just practice more with what I've got?
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
el_ingeniero
Re: Dremmel Trio or Alternative
#2 Post by el_ingeniero »
You could use a jig saw sled, or run the jigsaw against a straight edge clamped to the workpiece to cut straighter lines.
But the best and cleanest method might be to cut the holes with a plunge router. Then cut the tops separately. You can use the scrap left over from cutting the access panel for braces.
#3 Post by Bill Fitzmaurice »
I cut round holes with a router, rectangular with circular saw and sled, just using the jig saw to finish the cut in the corners.
BoostFab
#4 Post by BoostFab »
definitely get a router, since you can also use it for rounding cab edges.
doncolga
#5 Post by doncolga »
Router it is then. I suspected that'd be the case. Since I've never used one of these, any suggestions for a good one?
Donny Collins
Frederic Gelinas
#6 Post by Frederic Gelinas »
I have a Dremel. I broke it last year and I'm not missing it. I don't think I'll ever buy the parts to fix it. Get a plunge router.
Frédéric Gélinas, HF Audio
HFAudio.ca
Free tone Generator
doncolga
#7 Post by doncolga »
doncolga wrote:Router it is then. I suspected that'd be the case. Since I've never used one of these, any suggestions for a good one?
Since I'm asking, I'd need advisement on a drill press too. Harbor Freight has both of these:
http://www.harborfreight.com/1-1-2-half ... 67119.html
http://www.harborfreight.com/5-speed-dr ... 38119.html
Thanks!
Donny
Donny Collins
#8 Post by DJPhatman »
The router is a POS. I own the drill-press, and it is OK. Don't force it through material, like BB, too fast or else the motor will crap out. Check out subharmonics thread on routers. I recommended a Craftsman dual base for ~US$110 that has good power, a fixed and plunge base, 1/2" and 1/4" collets and works with a Jasper Jig.
doncolga
#9 Post by doncolga »
DJPhatman wrote:The router is a POS. I own the drill-press, and it is OK. Don't force it through material, like BB, too fast or else the motor will crap out. Check out subharmonics thread on routers. I recommended a Craftsman dual base for ~US$110 that has good power, a fixed and plunge base, 1/2" and 1/4" collets and works with a Jasper Jig.
This one?
http://compare.ebay.com/like/1807280608 ... r&_lwgsi=y
Donny Collins
#10 Post by Bruce Weldy »
If possible, spend the money for a combo kit that has plunge and fixed bases. Porter Cable, Bosch, etc. will cost more - but are better tools.
doncolga
#11 Post by doncolga »
Bruce Weldy wrote:If possible, spend the money for a combo kit that has plunge and fixed bases. Porter Cable, Bosch, etc. will cost more - but are better tools.
Yes, I do want to get something good that will last. Hopefully my four builds so far are just a start of many happy years of speaker building. If I keep at this pace, I should have 20 T30's by 2020. :hyper:
Donny Collins
#12 Post by Bruce Weldy »
This is the one I bought. Very nice piece of gear.
http://www.amazon.com/Bosch-1617EVSPK-4 ... B00005RHPD
doncolga
#13 Post by doncolga »
Thanks Bruce! So on this one, there's a plunge base and a fixed base correct? Fixed base is what'd use for something like rounding off corners correct...and plunge would be for cutting driver holes? What's concerning me here is, having never used one, I've only got a very basic idea as to what to do with it. I guess the two big things would be smoothing off corners and making the driver holes, as I mentioned. I'm sure I'll figure out more things as I go. Off bargain hunting...
I wonder if something like this would make it to a Black Friday sale?
Donny Collins
#14 Post by Bruce Weldy »
doncolga wrote:Thanks Bruce! So on this one, there's a plunge base and a fixed base correct? Fixed base is what'd use for something like rounding off corners correct...and plunge would be for cutting driver holes? What's concerning me here is, having never used one, I've only got a very basic idea as to what to do with it. I guess the two big things would be smoothing off corners and making the driver holes, as I mentioned. I'm sure I'll figure out more things as I go. Off bargain hunting...
Another great use is when your cab is just a little out of square - you can make the last side/top/panel oversized then use a pattern bit to make it flush. I just got mine during my last builds and used the heck out of it. Recessing the jack plate and handles, etc.....lots of uses.
#15 Post by Tom Smit »
doncolga wrote: What's concerning me here is, having never used one, I've only got a very basic idea as to what to do with it.
Search Youtube for ideas on how to use the router. Woodshop, Woodsmith, etc, etc, also provide ideas on video and with pictures.
