Home theater build - THTLP, TLAH, SLA-Curved
whipdancer
#1 Post by whipdancer »
I'm part way into building a full set of speakers for my media room. Since I already have pretty decent speakers, I decided to start with what I was missing - a subwoofer. Here is some partial coverage on the build of my THTLP.
Slideshow can be seen here...
Here are some shots of it finished in the media room - I'm building a box for the amp that will go somewhere...
It fits perfectly below the screen, firing into the corner.
Under construction:
Marking everything on one side...
Side to panel...
Panel 2, I think...
A little further along...
This is my work area...
And just for fun, this is how I got the wood home...
I've started on my SLA curved and will add those pics this weekend.
~Whip
bassmonster
Re: Home theater build - THTLP, TLAH, SLA-Curved
#2 Post by bassmonster »
Looking good so far, keep up the good work!
Fatso
#3 Post by Fatso »
looking forward to the curved center. I'm studying on that as my next project. Not to sure about my crossover skills.
whipdancer
#4 Post by whipdancer »
I'm actually working with 2 different sets of speakers for my speakers. I'm using the buyout Sony's and buyout JVC 3x5 from last year. Here is a look at my progress so far with the JVC's.
I should be able to make some progress this week - hopefully will get everything actually cut out.
~Whip
whipdancer
#5 Post by whipdancer »
Well, after much experimentation, I've come to the conclusion that the JVC 3X5 shape is not something I will be able to make look good. I'm too deficient in woodworking skills (currently). I'll put those to the side and get busy with the Sony buyouts, instead!
~Whip
el_ingeniero
#6 Post by el_ingeniero »
I'll buy 'em from you ... I have the cabs with the openings already cut out for them I got from someone else.
whipdancer
#7 Post by whipdancer »
el_ingeniero wrote:I'll buy 'em from you ... I have the cabs with the openings already cut out for them I got from someone else.
You have my attention. Let me count them (40ish) and I'll let you know exactly how many I have.
el_ingeniero
#8 Post by el_ingeniero »
PM me with a price.
whipdancer
#9 Post by whipdancer »
el_ingeniero wrote:PM me with a price.
You have a PM.
whipdancer
#10 Post by whipdancer »
Ok, finally got my curved center channel done.
Now I need to mount it ABOVE my screen (the space below is taken up by my THT-LP).
Any thoughts on how I could do that?
Thanks!
~Whip
whipdancer wrote:Ok, finally got my curved center channel done.
Thanks!
~Whip
Skyhook.
67baja
#12 Post by 67baja »
Thanks!
~Whip
Whip, I am going through the same thing. What I think I will end up doing is putting a single bolt through the center of each end of the center channel from the inside of the cab and the threaded end sticking out. Then I will use nice "L" brackets from the ceiling with the bolts going through them with nuts on the outside. That way I can angle the speaker how I like then tighten the nuts to hold it in place. Simple and effective.
whipdancer
#13 Post by whipdancer »
Bill Fitzmaurice wrote:Skyhook.
I googled Skyhook - found a projector mounting system that seems to be sold only in Australia. Am I not looking hard enough?
whipdancer
#14 Post by whipdancer »
67baja wrote:Whip, I am going through the same thing. What I think I will end up doing is putting a single bolt through the center of each end of the center channel from the inside of the cab and the threaded end sticking out. Then I will use nice "L" brackets from the ceiling with the bolts going through them with nuts on the outside. That way I can angle the speaker how I like then tighten the nuts to hold it in place. Simple and effective.
That's an interesting idea. I think I'll see what I can come up with along those lines.
You get skyhooks from the same place that you get shore line. :loler:
Weak attempts at humor aside just hang it, with screw eyes and wire, being sure to drive the screw eyes into joists.
