unsulation in cabinet interior
katu_lp
#1 Post by katu_lp »
Hi,
i'm about to put the insulation in the cabinet interior. i have some matress foam remains that i can use, but they are 2 inch thick....is it too thick, or it will do just fine?
bassmonster
Re: unsulation in cabinet interior
#2 Post by bassmonster »
katu_lp wrote:Hi,
What cab are you thinking about putting insulation in?
el_ingeniero
#3 Post by el_ingeniero »
The instructions should say exactly what kind of insulation to put in.
katu_lp
Re: insulation in cabinet interior
#4 Post by katu_lp »
I'm building an Omni12...
the manual says 1 1/2 in. mattress topper foam, the point is that i have some of that but its 2in thick, i wanna know if it's usable or if it's not recommended.....thanks
#5 Post by Bill Fitzmaurice »
2 inch is OK so long as it's not a memory foam. Memory foam has higher density and should not be used more than 1 inch thick.
katu_lp
#6 Post by katu_lp »
htanks bill! no, it's not memory foam...
since we are on the subject, do I have to put insulation in the baffle (except were the speakers are mounted, of course)? i'm building the 2x10 version, so there isn't much space either...
#7 Post by Bill Fitzmaurice »
katu_lp wrote: do I have to put insulation in the baffle
No.
