Coming from the home audio world I never really dealt with stacking speakers much.
So when is enough enough? How long can I make my chain? What am I losing with multiple speakers in a run? Pending I can make all the resistance balance out to 4-8 ohms, there has to be a limit. What happens if I stack 16 DRs on one channel running the whole stack at 8 ohms?
How many speakers is too many?
- subharmonic
I need more bass
CW Mcall
I need more bass
CW Mcall
- Rune Bivrin
Re: How many speakers is too many?
Nothing special, other than that you need a pretty powerful amp capable of redonculous voltage swing to use the stack to its full potential. And the wiring to make that happen will be a weird beast. Not easy to get it right on a busy day of rigging.
The scalability sucks, and it's just more convenient with more small amps.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
the ceiling is your limit pal
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
MADE
4- OT12'S BETAII
- Doug Hart
Ummm... a big party?subharmonic wrote:What happens if I stack 16 DRs on one channel running the whole stack at 8 ohms?
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
dB Pro Audio
- Jon Barnhardt
I've played some big events and would never envision needing more than 4 per side. Any bigger than that and you are looking at flying the PA anyway...subharmonic wrote:Coming from the home audio world I never really dealt with stacking speakers much.
