D-Fend
D-Fend
#1 Post by LelandCrooks »
I've been keeping an eye on these things. Think maybe it's time to jump. Would be perfect for the tubas/titans. And I believe they're going to be pretty affordable. There are several more videos, but nothing blows up in them. :twisted:
Re: D-Fend
They won't be available until October at the earliest. They had to change them to incorporate a USB port, otherwise the average user couldn't program them. AFAIK the retail will be in the vicinity of $50.
J_Dunavin
Re: D-Fend
#3 Post by J_Dunavin »
Does this go in line between the amp and driver?
gdougherty
Re: D-Fend
#4 Post by gdougherty »
Nice!
Re: D-Fend
#5 Post by LelandCrooks »
Inside the cabinet, runs from speaker line voltage. An external model is in the works.
Greg Plouvier
Re: D-Fend
#6 Post by Greg Plouvier »
Does the dfend unit die when it sees that kind of voltage? ( haven't read up on it yet) I wonder how it sounds - if you can hear it working.
Greg Plouvier
Israel
Re: D-Fend
#7 Post by Israel »
there are several videos but they do not quite explain other function than a protection circuitry (it is a signal processor also ?? ie xover maybe a phase correction like bbe maximizer )
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
Dan30
Re: D-Fend
#8 Post by Dan30 »
Around $50? What an investment! I do have 1U open in my rack, so a d-fend that's rackmountable would be sweet!
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Re: D-Fend
#9 Post by LelandCrooks »
In one of the videos they dump a 6k lab gruppen into at clip. No ill effects to the driver or the circuit.
Dan30
Re: D-Fend
#10 Post by Dan30 »
LelandCrooks wrote:In one of the videos they dump a 6k lab gruppen into at clip. No ill effects to the driver or the circuit.
I didn't hear him say where all of that power is actually going. I wonder if they've tested it for hours straight.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Re: D-Fend
#11 Post by Gregory East »
apparently this isn't "dissapitive" blowed if I know how it does it but sooooo clever.
253, views on that vid, obviously breaking news eh Leland! It'll be all over the interweb in a week.
Mindblowing capabilities!
Re: D-Fend
#12 Post by LelandCrooks »
I got the impression the excess power is diverted to another chip that essentially ramps up to infinite resistance. Just like the amp is unhooked from a load. When I first talked to tech at eminence about them they told me it's very musical, not abrupt or choppy at all like a limiter/compressor can be.
Dave Non-Zero
Re: D-Fend
#13 Post by Dave Non-Zero »
Jeeeez the guy is boring tho! I couldn't be bothered sitting thru it all! I didn't even get to the technical bit. Suppose I'll try again tomorro.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Re: D-Fend
#14 Post by Radian »
Rental company's wet dream. :P Brilliant!
Dave Non-Zero wrote:Jeeeez the guy is boring tho! I couldn't be bothered sitting thru it all!
I found it quite informative. That's only 10 minutes. Try five years for a BS. :lol:
Re: D-Fend
#15 Post by Gregory East »
LelandCrooks wrote:I got the impression the excess power is diverted to another chip that essentially ramps up to infinite resistance. Just like the amp is unhooked from a load. When I first talked to tech at eminence about them they told me it's very musical, not abrupt or choppy at all like a limiter/compressor can be.
Would that give a valve amp the heebie jeebies?
