Just picked up one of these amps to take over the sub duties. http://www.carvinguitars.com/products/s ... t=DCM3800L
Used it at an outdoor show last Saturday and was quite impressed. I used 4 T39's (3012LF). 2 per side. Had the limiter set at 53-54V. It just idled all night, while pounding the snot outa the subs. In the past I was running all four off a EP2500, all from 1 channel. Pulling about 2.5 ohm. I know it's been told many times here about running an amp this low. Although I never had a problem (other than some clipping) I recently read an article that stated even though your power goes up (with lower ohms) after going below 3 ohms the current is not constant. Now I run the OT12's two per side on a EP2500 also. Anyhow, the Carvin made a good first impression. Light weight, powerful, 3 yr warranty, and on sale right now. Really happy I bought one.
Carvin DCM3800L
Carvin DCM3800L
2 OT12's 2512 CD
2 OT12's 2512 Melded Array
4 Titan 39's 30" 3012LF
4 Titan 39's 20" 3012LF
6 Wedgehorn 8's
1 Wedgehorn10
2 AutoTuba's 18" w/MCM 8"
https://www.facebook.com/pages/LSW-Lana ... 080?ref=hl
2 OT12's 2512 CD
6 Wedgehorn 8's
1 Wedgehorn10
NCcrashman
Re: Carvin DCM3800L
Thanks for the great review. Carvin amp's have been on my "short" list based on their output (hopefully) and price. I have had horrible problems with QSC in the past but I have been told they're much better with less issue's. I believe Carvin will be in the top 2.
Please keep us informed of any problems you have in the long term.
Patrick
Patrick
"If it's too loud, your too old! What's that? I didn't hear you"
Friends don't let friends use crappy speakers!
