EQ Omni15TB
more4me
EQ Omni15TB
#1 Post by more4me »
Just unpacked my DEQ2496 and hooked everything up. With auto eq and a little tweaking, this was the result: :hyper:
The Omni15TB is equipped with the Deltalite3015lf.
Builds so far:
2x T39
2x Omni15TB
2x DR200
1x Omni10
Born Confused... and grown worse...
Re: EQ Omni15TB
You want to manually pull everything below 40 Hz all the way down. There's no point wasting amp power and driver excursion trying to work below the cab passband.
Doug Hart
Re: EQ Omni15TB
#3 Post by Doug Hart »
Does the DEQ not have a high pass?
Doug Hart, Owner
dB Pro Audio
http://www.hartdesignsetc.com
more4me
Re: EQ Omni15TB
#4 Post by more4me »
There is a HP and I'll set it to 40Hz. This thing was a lot easier to work with than I expected. Really simple for the EQ part, at least. Will be interesting to try out the dynamic EQ features as well :)
Builds so far:
2x T39
2x Omni15TB
2x DR200
1x Omni10
