OT12's and T30's Dialed in Outside
Post links to youtube videos of your cabs.
Forum rules
doncolga
#1 Post by doncolga »
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Drey Chennells
Re: OT12's and T30's Dialed in Outside
#2 Post by Drey Chennells »
Real nice Don..
edit: crackin a magic hat wacko brew for yas..
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
#3 Post by Tom Smit »
Nice video there Donny. It definitely shows how crisp the melded array is even at a distance. Nice and clear video as well, kudos.
doncolga
#4 Post by doncolga »
Drey Chennells wrote:Real nice Don..
LOL! Enjoy!
Donny Collins
doncolga
#5 Post by doncolga »
Tom Smit wrote:Nice video there Donny. It definitely shows how crisp the melded array is even at a distance. Nice and clear video as well, kudos.
Thanks man! I really wish I'd put the RTA in the video too, but it really doesn't matter much. My ears are happy now and it throws like hell, bass and all, on such little power. I also thought maybe I should have vplated too...I may do another one with that, or one inside with some loading. That's where they really, really shine. It will likely be a while, but I'm really looking forward to adding two more Tubas. I've got a local party here on July 2, so I should get some video of that.
Donny
Donny Collins
Drey Chennells
#6 Post by Drey Chennells »
The dimensions of the slim T30s together makes for a nice form factor with the OT12. Which is nice considering aesthetics can trump sound for some clients.. :roll: I imagine yours are impressed even before power ; )
InfraCoustik
doncolga
#7 Post by doncolga »
Drey Chennells wrote:The dimensions of the slim T30s together makes for a nice form factor with the OT12. Which is nice considering aesthetics can trump sound for some clients.. :roll: I imagine yours are impressed even before power ; )
That is true. Bringing is a large rig can freak people out sometimes.
Donny Collins
BCBoom
#8 Post by BCBoom »
Nice video. I had two of my OT12's along with 2 T39's set up outdoors at a wedding this past weekend. Didn't get time or a chance to run a video but the sound was great. Have a few more outdoors this summer, will have to try to get some video up.
BCBoom
Built: 4 x OT12 (Deltalite 2512 loaded), 2 x T39 (Kappalite 3012LF loaded), 2 x T48 (Kappalite 3012LF loaded), 1 x TAT
Future Build: 4 x T48 or T60
safebet
#9 Post by safebet »
Excellent video Donny, I really enjoyed it. Thank you for taking time to put it together.
If I had that large a space I would love to v-plate those little T30's near the back door, somewhere around the center of the back of your home. You could keep the OT12's wherever you want them (in the vicinity) and with your DCX just delay them a bit. Talk about a party space!
Again, rockin' video. I think it will be helpful to others.
Tom
2 x T30 23" -3012LF v-plate
2 x Econowave Deluxe HO (awesome custom tops using 3012HO and B&C DE250 on QSC horn)
1 x T39 25" -3012LF
1 x Autotuba -Tang Band
"No Toby, I said a PHILLIPS screwdriver..." (Used Cars, 1980)
Robby Hoinsky
#10 Post by Robby Hoinsky »
You have the T30's hooked up to one channel? Was the voltmeter reading the output going to both of them in parallel?
Robby
Authorized BFM Builder
http://www.ArtofNoiseAudio.com
Retailer of Eminence and Dayton loudspeakers
doncolga
#11 Post by doncolga »
Robby Hoinsky wrote:You have the T30's hooked up to one channel? Was the voltmeter reading the output going to both of them in parallel?
Robby
That was Amp Channel 1 to T-30 to T30 for a four ohm load. Each channel is rated 600 watts @ 4 ohms, so it should put out 48 volts, it seems like it goes much higher though.
Thanks!
Donny
Donny Collins
camrynekai
#12 Post by camrynekai »
Now just imagine 6 to 8 per side :) :) :) its just plain stupid
Facebook Page
My herd of T48's
Cabs built
14- 24" T48's 3015LF's
4- OTop 12's W/melded array's
2- 29" Sla Pro's
1- Auto tuba ITW
doncolga
#13 Post by doncolga »
camrynekai wrote:Now just imagine 6 to 8 per side :) :) :) its just plain stupid
Yeah...I'm looking forward to more for sure! Two more Tubas first, then two more tops.
Donny Collins
Titanium Hand
#14 Post by Titanium Hand »
:) Nice Video Donny, sweet looking rig to, very portable looking. Just a question on the input volts versus dB's. From what I saw you were hovering around 100dB @ 25 to 30 volts? I've got a very slight grasp of sensitivity and output... x 2, x 10 and so on. Have you fed it more juice toward the published recomended maximum? If so, do you think you would squeeze an extra 3 dB out of it?
Cheers mate
ripNdeb
#15 Post by ripNdeb »
Private video???????
