Hi again from Argentina
I m the happy owner of 2 x J112 and they ve been sounding great since I built them a year ago.
Now I have on hand 2 x Faital 15" FH500 woofers, for wich I built 2 x ported cabinets using WinISD Pro. (about 100 liters and tuned to 45 Hz). Faital speakers give good results on WinISD compared to other similar brands like B&C
I m concerned about this woofer s low Qts value of about 0,31.... Does anyone know if this Qts figure can alter low frequency reproduction in a bad way?
Sonically, I noticed that this reflex Faital loaded cabinet has an excelent transient response with an extended low fq response; but the low end is not as "warm" as with the Deltalite loaded Jacks.
Is that warmth that I feel with the Deltalites some kind of desireble transient distorsion?
Any opinion about Qts values? Should I consider using a woofer more like in the 0,4 Qts range to get a "softer" "warmer" sound?
Thanks for your time!!
QTS - FAITAL
miguelbassi
Re: QTS - FAITAL
sorry, forgot to paste the link of the faital driver
http://www.faitalpro.com/products/sched ... =151060100
Re: QTS - FAITAL
0.31 is not considered a low Qts. As for how it affects response, you already know that since you modeled in WinISD.miguelbassi wrote: I m concerned about this woofer s low Qts value of about 0,31.... Does anyone know if this Qts figure can alter low frequency reproduction in a bad way?
The Faital are not horn loaded.the low end is not as "warm" as with the Deltalite loaded Jacks.
miguelbassi
Re: QTS - FAITAL
ok, thanks a lot then.
I thought that if I use a higher Qts value speaker, it would sound "softer" at low frequencies (something that I can not see in WinISD)
