I didn't realize how little I knew about local lumber yards until I started trying to find plywood. I know that Lowe's in my area doesn't have the Aurauco that is recommended. My internet searches guide me to a huge mishmash of wholesale only/ generic home improvement/ might-be-just-the-place-I-need-but-I-can't-tell-for-sure links. I was hoping that someone might have a lead to decent suppliers around here.
Thanks all.
Portland Oregon plywood source?
- cheapbasslovin
Mrrmensneturguneffferremantun
Re: Portland Oregon plywood source?
You won't find Aurauco up here, unless its special order. Try Mr Plywood on SE Stark. They have BB 5x5 1/2" Sheets at $32.
http://mrplywoodinc.com
Good luck in your build.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
- cheapbasslovin
You are. The man.
Thank you very much. That is actually less than 15 minutes from my house so I should be able to check it out at my leisure.
No problem. They have "Bendy Ply" too, in 1/8" if you ever build DR's. They can rip 4x8 down to any size, about .50 a cut. Lots of different types of plywood. Ask them about "Special Plywood", its an Oak face. They have BB in half sheets as well, great place.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
