When do you use delay?
RENDOG
#1 Post by RENDOG »
When do you use delay and is it on the Tops or Subs?
Re: When do you use delay?
On the tops, to time align them with the backline instrument amps and drums.
doncolga
#3 Post by doncolga »
I've got a local job where I corner load the Tubas and they are about eight feet behind the tops, so last time I was there I believe the DCX 2496 was delaying the tops about 8 ms...you can set it to adjust by distance and I believe that's what I did.
I have another question related to this...should the horn length be part of the distance consideration?
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
#4 Post by Bill Fitzmaurice »
doncolga wrote: I have another question related to this...should the horn length be part of the distance consideration?
Yes. But delay below 100hz is very difficult, if not impossible, to hear, so don't delay the tops any more than aligning with the backline requires.
RENDOG
#5 Post by RENDOG »
Thanks.
osse
#6 Post by osse »
Do you mean that its of no reason to delay the tops to the subs when for example dj'ing and xover freq is around 100 hz? I guess it matters of roomsize and speaker placement?
#7 Post by Bill Fitzmaurice »
It depends how far in back of the mains the subs are placed. Less than 10 feet you may not hear any difference. You will with direct radiator subs. because they have so much harmonic content above the pass band.
