MCM 55-2982 12" Driver
Lastcat
#1 Post by Lastcat »
I am not a Sound Engineer, but I play one on TV :fruit:
Ok, just had to settle my curiosity too, so I picked up a single MCM 55-2982 12" Driver to test.
http://www.mcmelectronics.com/product/55-2982
I have 4 T39's at 24" Wide each, using the 3012LF Driver. I used 2 of the cabinets to test side by side and compare SPL, using the Radio Shack "Sound Level Meter", and testing the 55-2982 against the 3012LF. Here are my findings:
MCM 55-2982
Outside Diameter = 12.375"
Inside Diameter = 11.062"
BCD Diameter = 11.625
Overall Heigth = 5.75"
Weight = 10 lbs.
I burned in the driver using a 60hz Sine Wave at 10v for 8hrs. I raised the voltage to 40v and found that the 55-2982 had no complaints, I did not exceed 40v until the speaker was in the cabinet, didn't want to waste this driver before I had a chance to get it installed.
The driver fit into the access opening with no problem, and mounted to the existing mounting holes used for the 3012LF. The BCD for the 3012LF is 11.62". There is only one gasket, face mounted, as you can see in the pic. Also, the gasket will compress in about 30 seconds. I had to make sure to go back over each bolt, and re-tighten. Tightening the driver all the way down to the frame was adequate.
The Wire Connections were Spring Loaded, just push down on the connector, insert wire, spring pop's back up and makes contact. Not bad, easier than the 3012LF, but I always prefer soldering.
Here are the Sound Pressure Levels for each speaker, installed into a T39 24" Wide. I used a 60hz Sine Wave to test each driver installed, digital volt meter, and a XTi 4000 limited -3db.
3012LF
Volts SPL
1.5 = 108
2.6 = 111
3.7 = 113
4.8 = 115
5.9 = 117
7.3 = 119
8.9 = 120
10 = 121
11 = 122
13.2 = 123
16 = 125
19.2 = 126
Above 19.2 volts the Radio Shack Meter Maxed out at 126 db.
MCM 55-2982
Volts SPL
1.5 = 103
2.6 = 107
3.7 = 110
4.8 = 113
5.9 = 113
7.3 = 115
8.9 = 116
10 = 117
11 = 118
13.2 = 119
16 = 120
19.2 = 121
23 = 122
28 = 124
36.5 = 124
47 = 126
Over all sound was good, just not as loud, around 5-6db less in volume than the 3012LF. I really don't think there is much that would beat the 3012LF, its a great driver, period. But if someone was on a budget and wanted a less expensive driver to use, the MCM 55-2982 is not a bad choice, it will work for the price, just not as loud. But if someone was to build 4 and V-Plate them, then it would be a great combination, it would turn some heads.
For the price, I might build 4 more, and load the MCM's and just go with it, if ever I find a good deal on a 3012LF in the future I could always swap out drivers, (all 4 that is).
With music, I had the 3012 cabinet and the 2982 cabinet side by side, for sure the 3012 put out more volume. But the 2982 had a smooth bass response as the 3012 but at a lower volume. Overall, I think if someone wanted to use the 2982, it would work, especially if they plan to build 4 and V-Plate, they could reach some good db levels then. I guess it comes down to choice and $$$$.
Here is my current setup, 4 DR200's Pro 8 loaded, and 4 T39 24" wide 3012LF loaded.
Hope this helps.
Lastcat
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Charles Warwick
Re: MCM 55-2982 12" Driver
#2 Post by Charles Warwick »
Cool, you beat BoostFab to the review, so now he can complete his build in peace without everyone bugging him. :lol:
Well that's good to hear we have a very cheap driver option in case someone needs some bass on the especially cheap.
If i had to guess I'd bet that the total output of that driver is probably less than that of the s2012 or Delta12lf since the 2982 has more xmax (and the power handling seems adequate) but definitely lower sensitivity (seems to be around 4-5 db)than either.
So you would probably need two of these to match the s2012s or DeltaLfs in total output as the increase in sensitivity due to doubling of drivers gets you 3db, and then the higher power handling of the 2982 appears to gain about 2 extra db, so about 5db which is what the sensitivity difference appears to be.
I'm very tempted to just buy one to play with it since for less than 40 bucks it seems like such a fun thing to do....
Thanks for your effort. I'm sure we'll find out more about these as we go along. 8)
Lastcat
#3 Post by Lastcat »
Charles Warwick wrote:Cool, you beat BoostFab to the review, so now he can complete his build in peace without everyone bugging him. :lol:
Thats the truth :loler:
Actually I'm looking forward to his review too, I think he planned dual loaded T48. Should be interesting. Not sure how the 2982 would stack up against the 2012 or the Delta12lf, never have owned one. But, like you mentioned, the 2982 would be a choice for less $$$ and would need twice as many cabinets, verse's a 3012LF. They actually would work, and I think 4 Vplated, or even 8 Vplated would actually have a "Bite" for some bass, but not as serious as a T39, or even come close to a T48.
Currently Built:
4 T39 24" 3012LF
4 WH10 2510
4 DR200 Pro 8a
4 DR250 2510
Mikey
#4 Post by Mikey »
Thanks for the detailed report! A little disappointing, but what can be expected of a $40 "pro" driver? For guys on a tight budget, at least they'll "work".
To me, it seems that a good application for these would be dually Titans, with the drivers series-wired, IF you have more pack space than money. Four parallel cabs on one side of an amp @ 5 ohms, with a limiter @ 50-60v. Since the test results revealed that there's little to be gained by throwing a lot of power at these, 25-30v per driver would allow them to give adequate reliable output.
The question was asked about using these drivers in the Omnis. Probably not a great idea in the O12, given their low sensitivity. Might be okay parallel-wired in the 2x12 O15 ... it would give you a 4 ohm load while shaving a hefty chunk of change off of the build.
Albert Einstein
#5 Post by Gregory East »
badabump for the kid thinking of doing s2010 loaded T30's
bassmonster
#6 Post by bassmonster »
Gregory East wrote:badabump for the kid thinking of doing s2010 loaded T30's
i think that was me :wall:
i'll go for the lab 12 or the MCM discussed here
