Piezo Sounds Questions
doncolga
#1 Post by doncolga »
Hey,
I have the Goldwood 1016's and I gave them a listen for the first time last night sending them white noise. The main things I noticed were:
1. They were all pretty much the same volume. Just a few seemed a little quieter, but not too much. None were glaringly out of line.
2. I ran my first one, then subsequent ones, and they all got louder, but when I reversed the polarities, it didn't seem to make much difference on any of them. I had them set really close together side by side on the long dimension.
3. There seemed to be some variation in the frequencies I heard for the white noise I was sending them. That OK?
I hope to get a good bit done on the boxes today as I approach completion, so I just wanted to run this by the group.
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Mikey
Re: Piezo Sounds Questions
#2 Post by Mikey »
Leland is the expert when it comes to piezos. He just recently posted about this very subject. A quick search should get you there quickly.
Albert Einstein
#3 Post by LelandCrooks »
3 ranges in piezos. Low, Medium and high. The output volume is about the same, but the sound is distinctly different. I primarily use low and mediums for arrays. Get as much as possible out of them at that 2k range.
But in bigger arrays I will mix in a few of the high ones also.
doncolga
#4 Post by doncolga »
LelandCrooks wrote:3 ranges in piezos. Low, Medium and high. The output volume is about the same, but the sound is distinctly different. I primarily use low and mediums for arrays. Get as much as possible out of them at that 2k range.
Hey Leland! Thanks very much. I'm going to do another listen and sort this evening and do the pickin' for the melds.
Donny Collins
doncolga
#5 Post by doncolga »
I just painted my melded array and it seems to be going well. I made a little wad of masking tape and gently pressed into each of the openings so they'd be well covered. One more coat and I'll pull those out. I expect it will look pretty good.
So since the new piezos are really stuck together, can one be fixed if it goes bad?
Donny Collins
#6 Post by LelandCrooks »
I think so. I have one to repair after about 4 years of pounding, so I'll let you know.
