Hi y'all
altoproxima
Hi y'all
#1 Post by altoproxima »
Guess it's proper to do a little introduction. Names Tim, born and raised in Belgium, which is south of Holland and north of France. ... Ummm well the country with a temporary governement :D
Anyway, i've been reading up on alot of threads here and I find it very interesting to say the least. I haven't started building anything yet, but I will soon start when I have time on my hand and when I have catched up reading alot more forum posts. I am still looking for what to build, though I have bought three building plans (kinda reckless .... I know) without knowing wichever to pick. Sometime later I will post a thread on what I do and what I want to achieve. For now it's important that I read up some more literature here.
Kind regards.
bzb
Re: Hi y'all
#2 Post by bzb »
Welcome!
What are you using the cabs for? That will help us give you some advice on cabs.
I was born near Bruges!
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
Re: Hi y'all
#3 Post by Tom Smit »
Welcome!
Too bad you didn't order the CD because then you could pick and choose what cab to build when the urge strikes you.
altoproxima
Re: Hi y'all
#4 Post by altoproxima »
Thanks for the welcome. Good to know there are some people with belgian roots.
Well tom yeah, it's realy dumb very impulsive to buy two plans, wanting to start building, but not knowing what you are going to get into. :wall:
Today i'll order the CD version with all the plans 99 dollars is nothing compared to the knowledge and quality plans you get deliverd.
Anyway, concerning the type of speakers I am going to build or will be building. I'll try to be very specific. The idea is to have a very flexible system to support all kind of bands in different situations. Most of the time will be in rather small venues like a bar with I suppose a maximum audience of 70 people without the need to reinforce the drums. Then places like where you get atleast 3 to 500 people and perhaps later outdoors with a maximum capacity of a 1000. Right now I have to depend on a friend for both FOH and monitors, like yesterday, I just needed two powered mackies to reinforce the vocals and monitors. I'dd like to have this myself since the more you need to rent to more profit of a gig you loose. So, in a first fase, monitors and a full range system would be the way to go I guess, unless you people here have a better idea, then I would like to hear about that.
Re: Hi y'all
#5 Post by DJPhatman »
altoproxima wrote:I'll try to be very specific. The idea is to have a very flexible system to support all kind of bands in different situations. Most of the time will be in rather small venues like a bar with I suppose a maximum audience of 70 people without the need to reinforce the drums. Then places like where you get atleast 3 to 500 people and perhaps later outdoors with a maximum capacity of a 1000. Right now I have to depend on a friend for both FOH and monitors, like yesterday, I just needed two powered mackies to reinforce the vocals and monitors. I'dd like to have this myself since the more you need to rent to more profit of a gig you loose. So, in a first fase, monitors and a full range system would be the way to go I guess, unless you people here have a better idea, then I would like to hear about that.
First, welcome to the forum, and addiction!
Do you have access to wood-working tools and space to work? What you are asking for is a modular system, something us "old-timers" advocate constantly.
My advice for a system is DR250 or OTop12, T39 and Wedgehorn 8 monitors. If you have the time, patience and tools, build DR250, otherwise build Omni Top 12. 6-8 DR250 will handle 1000, a pair will be overkill for 70-100. Build the T39s as wide as you can lift, transport, store and fit through door openings (remember, you can turn it sideways!) and use the best driver available to you. As for the Wedgehorns, if you use multiple monitor mixes, build enough 8" to cover the vocals, and maybe 1-2 10" versions for the drummer/bassist/keys, and the 10" can do side-fill duty, when not needed.
altoproxima
Re: Hi y'all
#6 Post by altoproxima »
I do have all neccesary power tools and stuff. Space is something different. Think I first need to clean op my work place if I look at all those tidy workplaces of some of the guys here.
A modular system is exactly what I am looking for, and I suppose I have come to the right place for that according to what I have read and seen so far. I too believe in having a modular system is the right way to go about handeling gigs the proper way.
The addiction of building is something I frequently read about, should I start to worry now ? :lol:
lincsoldbird
Re: Hi y'all
#7 Post by lincsoldbird »
Yes big time, half the the fun is in the build! :clap:
built 4 T30 24in BP102 now sold 2 DR280
2 speakerplans 1850, 2 MT102 ,2 X15, 1 G sub now sold
2 T60,s Built plus 4 DR280,s in the build
SeisTres
Re: Hi y'all
#8 Post by SeisTres »
altoproxima wrote:Thanks for the welcome.
I'd recommend jacks, but if you can build dr's, go for it man. The thing about jacks is that it's a really nice cab as far versatility is concerned, but it is not something that you'd want to add to. As for the dr's, you can do the adjustable tunning ports and run the full range for the smaller gigs and once you add subs, you let them off their leash and really let them scream. However, if you're ever going to need the jacks as backline, side fills, rentals or just anything that requires simplicity, I think you would be happy with 2 jack12's for the meantime and simply add a pair subs right after that and then you can really decide which tops you're going to expand.
doncolga
Re: Hi y'all
#9 Post by doncolga »
lincsoldbird wrote:Yes big time, half the the fun is in the build! :clap:
+1 I was thinking of this today as I was proudly sanding my OT12's, considering the time I had in them and my Tubas. You measure and cut each piece, fit, glue, screw till it's done, then hopefully you hear them sing. You'll be really proud of them man. I heard some JBL dual 18's again at church today that *used* to impress me so much. I can't believe how big and heavy those things are!
Welcome and good luck on your research, selection and build.
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
