Or would be better a QSC 2450RMX and QSC1450RMX respectively.
Now I have 6 ,T-48 with Kapalite 3015LF Eminence speakers and I have 6 new speakers for 6 other titans, just that and started doing the DR250 and DR250 makes 8, 4 per side.
Thanks.
the yamahas aren't rated to 2ohms as far as I know.Greg Plouvier wrote:If you must run amps at 2 ohms which I personally don't recommend, I would use the yamahas. I hope your HF drivers are 16 ohm.
SONIDO TUMBAO wrote:Haber si alguien de mis amigos del foro me ayuda con la traduccion.
No trabajaria las bocinas de 10" a 2 Ohms, ya que pondre la BETA 10B, que son a 16 Ohms, y las 4 bocinas en paralelo me dan 4 Ohms, y esas las usaria en un canal del Yamaha P7000S o el QSC 2450 RMX. I will be using the beta10b which is 16 ohm and running four per channel which would be 4 ohm on each channel of either the p7000s or 2450
En cuanto a los drivers AD1000S, esos viene a 16 Ohms, los conectare en serie en cada DR250 para que me den 32 ohms, y asi al conectar los 4 DR250 me den 8 Ohms en Total. Los cuales los usaria en un Yamaha P2500S o en un QSC 1450 RMX. As for the HF drivers, they are 16 ohm and will be wired in series in the cab making them 32 ohm. They would be 8 ohm with eight (4drs) channel. For this I would use the p2500s or 1450
Por eso la duda de que amplificador usar para obtener un sonido claro, nitido y no saturar el amplificador.
Gracias y disculpen si escribo en español, pero en ingles no sabria como ponerlo.
This is the reason I'm asking about which amps to use to get clean sound without stressing the amps.
"By the way, do you know the aprox weight of the DR250, loaded with BETA10 and ASD1001s?"SONIDO TUMBAO wrote:Por cierto, saben el peso aproximado de los DR250, Cargados con BETA 10 Y Driver's Ad1000s ?
