Baltic Birch Prices
turbovolkswagen
Baltic Birch Prices
#1 Post by turbovolkswagen »
Just went to a local lumber yard yesterday...
$85 for a 5x5 1/2 in sheet!
:wall: :wall: :wall: :wall:
CharlesC
Re: Baltic Birch Prices
#2 Post by CharlesC »
Where was this? I just called a lumber yard yesterday and was quoted $25. I'm in southern California.
#3 Post by LelandCrooks »
Find another yard.
turbovolkswagen
#4 Post by turbovolkswagen »
RI, I checked another place in ct and they quoted me $60 for a 5x5 that was veneered.
#5 Post by Bill Fitzmaurice »
turbovolkswagen wrote:RI, I checked another place in ct and they quoted me $60 for a 5x5 that was veneered.
You do not want to use veneered plywood. The grade of Baltic Birch you want is B/BB. A fair price is $35-$40.
turbovolkswagen
#6 Post by turbovolkswagen »
Yeah i read in the plans to avoid veneered. I ended up getting a 6 or 7 ply fir that looks pretty nice. It was much cheaper, like 20ish for a 4x8. I'm going to use this for my otops and track down some cheaper bb for the t30's when I get to them.
#7 Post by Gregory East »
They explained why plywood is always odd numbers of plys in primary school woodwork class. I forget now.
Greg Plouvier
#8 Post by Greg Plouvier »
BB does fluctuate. It's $28 right now here. Last year it went up to $65 for a bit. Don't buy it from a lumber "store". Find a yard. In other words they don't sell tools, garden supplies etc. - just lumber.
Greg Plouvier
bzb
#9 Post by bzb »
Paid $28 a sheet last week. They've been as low as $18, but gas prices are getting the blame.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
jjohnson
#10 Post by jjohnson »
Gregory East wrote:They explained why plywood is always odd numbers of plys in primary school woodwork class. I forget now.
To keep the outside plus the same direction??
turbovolkswagen
#11 Post by turbovolkswagen »
Greg Plouvier wrote:BB does fluctuate. It's $28 right now here. Last year it went up to $65 for a bit. Don't buy it from a lumber "store". Find a yard. In other words they don't sell tools, garden supplies etc. - just lumber.
It was a lumber yard
Harley
#12 Post by Harley »
Go to the top of the class jjohnson :clap:
No, it was a den of thieves posing as a lumber yard.
Harley
#14 Post by Harley »
AKA "Ali BB and the Forty Thieves" :mrgreen:
#15 Post by Gregory East »
I vote google to top of the class "why does plywodd have odd numbers of plies"
We asked the question in our last newsletter: Why does plywood have an odd number of layers (plies)?
Actually we said it always has an odd number, which isn’t entirely true. Some low grade plywood has an even number of plies. But do yourself a favor and stay away from that stuff.
To understand why plywood has an odd number of plies, first we’ll take a quick look at how it’s made.
Veneers are cut from the trees in thin layers. These layers will become the plies of the board. When the plies are layered and glued together, they are arranged at 90 degree angles to each other. This helps to keep the plywood from expanding and shrinking based on moisture in the environment. The alternating construction creates a board that is much stronger in each direction than a similarly sized board cut from a single tree.
Now that we have a basic idea of how the material is made, we can better understand why an odd number of plies is ideal. The short answer is: symmetry. We already know that the expanding/shrinking problem was solved by aligning the plies at 90 degrees to each other, but what about other problems like warping? Well if the plywood has an odd number of plies, it won’t warp*. It will have a middle ply, and that middle ply means the material is symmetrical. If a ply on one side of the middle is trying to warp the board, it will have the opposite force on the other side preventing it from doing so.
So there you go, it’s a pretty simple reason, but a reason that not many people think about. It reminds me of something I was taught while training: Whatever you do to one side of the board, do to the other. In some cases painting a board can cause it to warp. But if both sides are coated, you make the board symmetrical, and warping will be less likely.
*under extreme conditions it can still warp, it is wood after all.
