So I'm currently building 2 wedgehorns, then going to outfit my current Jack 12 with the high end section, then build another Jack 12 so I have a solid small PA setup. But for now I can use other tops, but don't have any good monitors so Wedgehorn it is!
So first I went and got a sheet of Arauco from Lowes, I was able to find a nice sheet which made me happy (it's the little things)
Then I spent a little time with the program cutlist so I could map out how to get 2 Wedges out of one sheet. I didn't butt things up like I could have, instead I cut out a rectangle for each piece. It made the cutting go extremely fast, still left me with a few odds and ends, and really just made everything simpler for me. After those initial cuts, I cut down each piece (well I still need to cut the baffle out of an 11" square) and have started assembling the boxes. Annnnnnd I will keep this thread updated
As you can see, I got the cutlist to let me make 7 cuts across the board and then work with each of those boards. My father is currently building his own house (well GC) and the builder has a lot of his equipment there so I got to use his nice table saw which made these cuts a breeze.
Then I cut them to their right shape and size, and assembled the shell.
