4 dr200's an a EP2500
Posted: Tue Mar 29, 2011 1:09 pm
by Scott Brochu
Would one channel of a EP2500 be able to handle 4 dr 200's with the Beta 8 8ohm?
Re: 4 dr200's an a EP2500
Posted: Tue Mar 29, 2011 1:43 pm
In theory yes, but I don't like running at minimum loads. I'd rather use 16 ohm Delta Pros.
Posted: Tue Mar 29, 2011 1:51 pm
by Scott Brochu
OK thanks Bill.
I could probably run 2 on each channel with no reason for worries?
Posted: Tue Mar 29, 2011 2:01 pm
by netwerks
Scott Brochu wrote:OK thanks Bill.
If you ran the 16ohm version you could run 4.
Posted: Tue Mar 29, 2011 2:22 pm
by DJPhatman
Yes, with 8 Ohm drivers, 2 on a channel presents a 4 Ohm load.
Posted: Thu Mar 31, 2011 12:04 pm
by Stage Craft
I too am looking to drive four DR250's. A quad of them with the 2510 driver has an RMS of 1000watts. Is it proper to run that much to them, and if so, how much over rated should the amp be?
I'm looking at a QSC RMX 1450 which delivers 400-450 watts per ch. at 4 Ohms. Good choice? Here is a data sheet:
http://qscaudio.com/products/amps/rmx/rmx.htm
Sorry for the noob question.
Scott, I hope I'm not high jacking your thread.
Thanks,
Posted: Thu Mar 31, 2011 12:47 pm
Stage Craft wrote:I too am looking to drive four DR250's. A quad of them with the 2510 driver has an RMS of 1000watts. Is it proper to run that much to them, and if so, how much over rated should the amp be?
I'm looking at a QSC RMX 1450 which delivers 400-450 watts per ch. at 4 Ohms.,
Anything more than 200 watts each with DR250s gives additional headroom but no additional output.
Posted: Thu Mar 31, 2011 1:26 pm
by Scott Brochu
Stage Craft wrote:Scott, I hope I'm not high jacking your thread.
Thanks,
No thats fine. :)
I'm still learning also so there is no bad questions.
I think I might hook them up to my XLSCrown1000 and at least try them this weekend. I have never heard a DR200 so I am looking foward to listening. To bad I am behind the kit the whole night. :cry:
Posted: Thu Mar 31, 2011 2:09 pm
by Stage Craft
Thanks Bill! Thanks Scott!
