4 dr200's an a EP2500
- Scott Brochu
Would one channel of a EP2500 be able to handle 4 dr 200's with the Beta 8 8ohm?
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: 4 dr200's an a EP2500
In theory yes, but I don't like running at minimum loads. I'd rather use 16 ohm Delta Pros.
- Scott Brochu
OK thanks Bill.
I could probably run 2 on each channel with no reason for worries?
If you ran the 16ohm version you could run 4.Scott Brochu wrote:OK thanks Bill.
Yes, with 8 Ohm drivers, 2 on a channel presents a 4 Ohm load.Scott Brochu wrote:OK thanks Bill.
Stage Craft
I too am looking to drive four DR250's. A quad of them with the 2510 driver has an RMS of 1000watts. Is it proper to run that much to them, and if so, how much over rated should the amp be?
I'm looking at a QSC RMX 1450 which delivers 400-450 watts per ch. at 4 Ohms. Good choice? Here is a data sheet:
http://qscaudio.com/products/amps/rmx/rmx.htm
Sorry for the noob question.
Scott, I hope I'm not high jacking your thread.
Thanks,
Thanks,
Peace and Good Tone,
Anthony Bonadio
St. Louis, MO
Check out my day job(s):
http://www.stagecraftgear.com
http://www.reasonamps.com
Anthony Bonadio
St. Louis, MO
Anything more than 200 watts each with DR250s gives additional headroom but no additional output.Stage Craft wrote:I too am looking to drive four DR250's. A quad of them with the 2510 driver has an RMS of 1000watts. Is it proper to run that much to them, and if so, how much over rated should the amp be?
I'm looking at a QSC RMX 1450 which delivers 400-450 watts per ch. at 4 Ohms.,
- Scott Brochu
No thats fine.Stage Craft wrote:Scott, I hope I'm not high jacking your thread.
Thanks,
I'm still learning also so there is no bad questions.
I think I might hook them up to my XLSCrown1000 and at least try them this weekend. I have never heard a DR200 so I am looking foward to listening. To bad I am behind the kit the whole night.
Stage Craft
Thanks Bill! Thanks Scott!
Anthony Bonadio
St. Louis, MO
Anthony Bonadio
St. Louis, MO
