SPL meter that reads higher than 130dB
Dave Non-Zero
#1 Post by Dave Non-Zero »
Hi! I'm needing an SPL meter that reads higher than 130dB so i can accurately measure hte output from my system.
The one i have is fine up to the high 120s then it starts to read 'over' when it is clearly getting much louder :)
Im not looking to pay hundreds for a meter just for this purpose though, so if thats the case I'll just settle for what i have or the time being.
you can just see the 'over' in the bottom right of the meters screen.
This was my dually t60 in the corner with a 40Hz tone going to it.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Israel
Re: SPL meter that reads higher than 130dB
#2 Post by Israel »
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
#3 Post by Bill Fitzmaurice »
Measure at the middle of the room. If it reads over 115dB you're too damn loud. :cussing:
Meters that read over 130dB are very rare and very expensive.
BrentEvans
#4 Post by BrentEvans »
If you use RoomEQWizard and an external mic and preamp, you are limited only by the distortion ceiling of the mic. You can calibrate at a lower SPL, then read on up into the sky. The Audix TM1 is rated to 130db at 1%THD, but tops at 140. It's also $300... and they go up fro there. I have a Dayton EMM6 (same as behringer ECM8000) and it goes to 127db... probably a ltittle less max as the Audix, but it's $50.
You can use a decent dynamic mic and go louder, but accuracy in frequency response is limited by the mic. However.... with a 57 or 58 and a cheap USB pre, you can have a PC based SPL meter for under $200.
