Thanks for any input.
First build. Tuba 24's. Wiring question to daisychain
Captain Awesome
- SoundInMotionDJ
Re: First build. Tuba 24's. Wiring question to daisychain
Wire the jacks in parallel.
And...consider swapping the 1/4" for speakon.
--Stan Graves
--Stan Graves
10 T39S + 10 DR200 + 1 T48
So, + from both jacks to + on speaker and both - to -. Correct?
Other than I'm assuming that the speakons lock in, what other benefit is there. I ask mostly because all of my cables are 1/4"
Captain Awesome
Also, are most guys doing the passive crossover, and or the high pass filter?
Captain Awesome
-multi conductor in speakon to allow for 2 way or 3 way signals to be sent and not just rely on passive crossover in the cab
-allows higher gauge wire to be used
-contact pins on speakon are not exposed (less chance of shorting amp)
Speakons are designed to work as loudspeaker connectors. 1/4" are designed for telephone switchbays. It's a simple matter of right tool versus wrong tool.DMueller wrote:So, + from both jacks to + on speaker and both - to -. Correct?
Greg Plouvier
Speakons are sealed - phone jacks leak air. Speakons make better contact. Changing your cables to speakon is easy-no soldering requiredDMueller wrote:Other than I'm assuming that the speakons lock in, what other benefit is there. I ask mostly because all of my cables are 1/4"
Greg Plouvier
- SoundInMotionDJ
Correct.DMueller wrote:So, + from both jacks to + on speaker and both - to -. Correct?
Plus, you don't have to worry about some yahoo trying to run the speakers with a guitar cableBill Fitzmaurice wrote:Speakons are designed to work as loudspeaker connectors. 1/4" are designed for telephone switchbays. It's a simple matter of right tool versus wrong tool.DMueller wrote:So, + from both jacks to + on speaker and both - to -. Correct?
Upgrade to Speakon - you won't regret it. And use the NL4 not the NL2.
- Dave Non-Zero
Also the jacks can short out momentarily as you plug them in and out. Hence the horrible noises as guitarists plug in. Speakons don't, so you are safe unplugging them without blowing your speakers or amps.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Wow, you guys hit hard and fast. Thanks for the help. I guess I'm switching.
Captain Awesome
If only our wives and children would listen this well.....DMueller wrote:Wow, you guys hit hard and fast. Thanks for the help. I guess I'm switching.
Bruce Weldy wrote:If only our wives and children would listen this well.....DMueller wrote:Wow, you guys hit hard and fast. Thanks for the help. I guess I'm switching.
wifey is the hitter of my house im just the speed bag
about the speakon cables worth the change bought the plugs and made mines myself .....pennywise
MADE
4- OT12'S BETAII
4 T39'S 20" 3012LF LOADED
ON THE BENCH: 2 OT212
MADE
4- OT12'S BETAII
- Dave Non-Zero
I once forgot to strap my tops together one time and the top one walked off the front until it tipped off the front and was only held by the short speakon link lead from the cab below.
scary but true.
speakons rule and are worth significantly more than their weight in lawyers!!!!!
scary but true.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Tom O'Shea
One lawyer=2-3,000 speakons? Not giving speakons enough credit.
Plus, speakons are made in Lichtenstein. Dude! How cool is that?
Tom O'Shea
Auburn, AL USA
Auburn, AL USA
