Anyway, I'll poct some pictures along the way. If I like it, I will def build another one, with nicer wood of course
AutoTuba build. This is the last time...
digital_chris
I use ANYTHING but Baltic Birch. I haven't worked with Baltic yet, but my TT I used MDF, nice and flat but the dust is no good to breath, now some crap plywood, only slightly warped and it still sucks. Drilling into it causes chips, etc etc, ughh..
Re: AutoTuba build. This is the last time...
Drill small pilot holes first....then http://www.billfitzmaurice.info/forum/v ... 14&t=11285digital_chris wrote:Drilling into it causes chips, etc etc, ughh..
I feel your pain
digital_chris
It was chipping even with small pilot holes (5/64"), mostly when the bit exits the bottom of the wood
I mean, it's not a HUGE deal but I'd rather have a clean hole top and bottom of course.
I will keep in mind that trick for drilling close to the edge though, thanks for that
That's technique. When you drill through wood put a piece of scrap wood below it and that won't happen. If you have a drill press you never use just the metal table, you always have a piece of scrap wood on the table to receive the bit and prevent chipping and tear out.digital_chris wrote:It was chipping even with small pilot holes (5/64"), mostly when the bit exits the bottom of the wood
digital_chris
So it's not necessarily the wood but my technique? I'll give it a try, I know when I was drilling through both pieces together , the only chipping I got was wherever the bit exits the wood so it makes sense. From now on, I'll find a way to use scrap on the bottom
Thanks.
Thanks.
- Dave Non-Zero
And use a high speed. I always try and use my mains powered drill for drilling because the slower speed of my cordless means more chance of chipping. And a nice sharp drill bit makes a big difference.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
digital_chris
Another good point, use high speed. Don't know why I didn't think of that
digital_chris
Here are some shots of the beginning...
Tomorrow morning I should have some more pieces pre-drilled and bolted together
digital_chris wrote:I use ANYTHING but Baltic Birch. I haven't worked with Baltic yet, but my TT I used MDF, nice and flat but the dust is no good to breath, now some crap plywood, only slightly warped and it still sucks. Drilling into it causes chips, etc etc, ughh..
To avoid chips, place a scrap piece of board under the one you are drilling should come out clean...
Already covered, post #4. Forum etiquette: Read the entire thread before posting.dno1gtbai wrote:
digital_chris
Hey Bill, I just got panels 1-4 screwed and glued to the side panel. Since my plywood is a bit warped, I can't get a few of them screwed/clamped perfectly at 90 deg to the side panel, will that mess up the cab tuning enough to worry? It's not that bad, but where panel 2 meets up with panel 3 at the 55 degree angle, (45 for me), neither part came out to be 90 degrees perpendicular, each a few degrees off.
Bill Fitzmaurice wrote:Already covered, post #4. Forum etiquette: Read the entire thread before posting.dno1gtbai wrote:
dident read the whole post. jus saw the first post and try to post ... was in a rush to leave the house ...
It won't bother response at all.digital_chris wrote:Hey Bill, I just got panels 1-4 screwed and glued to the side panel. Since my plywood is a bit warped, I can't get a few of them screwed/clamped perfectly at 90 deg to the side panel, will that mess up the cab tuning enough to worry? It's not that bad, but where panel 2 meets up with panel 3 at the 55 degree angle, (45 for me), neither part came out to be 90 degrees perpendicular, each a few degrees off.
digital_chris
Good news, thank you
digital_chris
I just want to throw this thing away and start over! Son of a, this wood is by far the best to use. I know I'm stating the obvious but I just need to vent. My braces are being the biggest PITA, I can't cut them well, always coming out too wide or too narrow and I have no easy way to correct them. I just had to walk away even though I didn't want to... ughhh.
