Understanding amps
Posted: Sun Jan 30, 2011 7:53 pm
by Scott Brochu
In my set up I have a Mackie amp. One channel is for 1 Wedge10 and the other is for 2 Wedge 10's daisied.
The lead singer with 2 had problems saying one or both where going out. I couldn't tell I was behind the kit.
Now correct me if I am wrong; Is one channel 4 ohm load (2 W10's) and the other an 8ohm load with one wedge?
Would this cause one amp channel to be knocked out?
This is the amp
http://www.guitarcenter.com/In-Store-Us ... 1726488.gc
Re: Understanding amps
Posted: Sun Jan 30, 2011 9:21 pm
by Gregory East
Scott Brochu wrote: Now correct me if I am wrong; Is one channel 4 ohm load (2 W10's) and the other an 8ohm load with one wedge?
yes
Not unless it's sick. You could hardly be over driving it with two wedges.
Good luck finding the fault. Very hard to chase things that are off and on at random.
Posted: Mon Jan 31, 2011 3:57 am
by Rune Bivrin
I've had that happen with two W8-s on an amp channel. As far as a I could tell the amp wasn't happy about the piezo load. I could probably have fixed that by raising the series resistor, but decided the amp wasn't really up to the task. Haven't had it happen since.
Posted: Mon Jan 31, 2011 5:07 am
by DJPhatman
Rune Bivrin wrote:I've had that happen with two W8-s on an amp channel. As far as a I could tell the amp wasn't happy about the piezo load. I could probably have fixed that by raising the series resistor, but decided the amp wasn't really up to the task. Haven't had it happen since.
+1. I have a Tapco J-1400 (Mackie built the amp) and it does not like piezos at all.
Posted: Mon Jan 31, 2011 4:41 pm
by Scott Brochu
If it don't like the piezos than what are my options?
Do I bitch slap it :P
It worked with one wedge on each channel after I unhooked the daisy chained one.
did yours have fault also with 2 or just one?
Posted: Mon Jan 31, 2011 9:43 pm
by DJPhatman
Yes, bitch slap it! :noob:
I'm not sure about what to do. Get your lead singer some hearing tests? If a WH10 isn't enough, he has serious hearing problems.
Posted: Tue Feb 01, 2011 3:11 am
by Rune Bivrin
You can try raising the series resistor for the piezos to 10 ohms. That'll tame the capacitance a bit, but possibly result in a slight loss of top end.
The correct answer is really to have a better Zobel network on the output of the amp, since the issue can also be with the capacitance of the cables. However, that's a bit of an overly technical solution for most of us. If possible you could try using shorter cables.
Posted: Tue Feb 01, 2011 2:11 pm
by Scott Brochu
Rune Bivrin wrote:You can try raising the series resistor for the piezos to 10 ohms. That'll tame the capacitance a bit, but possibly result in a slight loss of top end.
The cables are speakon and are 25' runs with a 3' between the 2 that are daisied.
I only have that wedge infront of me to look at the filters. (which look fine)
I think I am going to bring the whole system home and look at it closer.
Thanks for the help guys. :mrgreen:
