In my set up I have a Mackie amp. One channel is for 1 Wedge10 and the other is for 2 Wedge 10's daisied.
The lead singer with 2 had problems saying one or both where going out. I couldn't tell I was behind the kit.
Now correct me if I am wrong; Is one channel 4 ohm load (2 W10's) and the other an 8ohm load with one wedge?
Would this cause one amp channel to be knocked out?
This is the amp
http://www.guitarcenter.com/In-Store-Us ... 1726488.gc
Understanding amps
- Scott Brochu
Understanding amps
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: Understanding amps
yesScott Brochu wrote: Now correct me if I am wrong; Is one channel 4 ohm load (2 W10's) and the other an 8ohm load with one wedge?
Not unless it's sick. You could hardly be over driving it with two wedges.Would this cause one amp channel to be knocked out?
Good luck finding the fault. Very hard to chase things that are off and on at random.
- Rune Bivrin
I've had that happen with two W8-s on an amp channel. As far as a I could tell the amp wasn't happy about the piezo load. I could probably have fixed that by raising the series resistor, but decided the amp wasn't really up to the task. Haven't had it happen since.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
+1. I have a Tapco J-1400 (Mackie built the amp) and it does not like piezos at all.Rune Bivrin wrote:I've had that happen with two W8-s on an amp channel. As far as a I could tell the amp wasn't happy about the piezo load. I could probably have fixed that by raising the series resistor, but decided the amp wasn't really up to the task. Haven't had it happen since.
- Scott Brochu
If it don't like the piezos than what are my options?
Do I bitch slap it
It worked with one wedge on each channel after I unhooked the daisy chained one.
did yours have fault also with 2 or just one?
Do I bitch slap it
Yes, bitch slap it!
I'm not sure about what to do. Get your lead singer some hearing tests? If a WH10 isn't enough, he has serious hearing problems.
- Rune Bivrin
You can try raising the series resistor for the piezos to 10 ohms. That'll tame the capacitance a bit, but possibly result in a slight loss of top end.
The correct answer is really to have a better Zobel network on the output of the amp, since the issue can also be with the capacitance of the cables. However, that's a bit of an overly technical solution for most of us. If possible you could try using shorter cables.
In build order:
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
- Scott Brochu
The cables are speakon and are 25' runs with a 3' between the 2 that are daisied.Rune Bivrin wrote:You can try raising the series resistor for the piezos to 10 ohms. That'll tame the capacitance a bit, but possibly result in a slight loss of top end.
I only have that wedge infront of me to look at the filters. (which look fine)
I think I am going to bring the whole system home and look at it closer.
Thanks for the help guys.
