DEQ2496 question
mattaudio
DEQ2496 question
#1 Post by mattaudio »
Can the DEQ2496 EQ 2 channels completely separate? Or is it limited to the same curve for a stereo signal?
I'm hoping to be able to control a mono main mix and a single monitor mix in 1 rackspace for ringing out the mixes, and I just think the dual 15-band analog setups in 1 rackspace would not be ideal.
The main output would go to my XTI amp which does the crossover and flattens the response for the speaker setups I use. The monitor mix would go straight to two powered wedges on stage.
Thanks for the advice!
Re: DEQ2496 question
#2 Post by LelandCrooks »
Separate. Easy to setup. I ran like that all the time.
