I thought this might fit here.
I getting used to delaying tops via XTI dsp, almost every show. I am finding it really clears up a mix especially when subs are placed near the backline. I have been seeing the tops set anywhere from 5-17 feet. 4 tops and 2-4 subs every show.
Is this normal to change every show?
Does anyone have more insight on delay or experience?
Delay
Re: Delay
Delay with respect to the subs is a minor concern, it's delay to match the tops with the backline that's critical for best results. It will be different in every room depending on the distance from the backline to the tops.
Re: Delay
So if the back line is ten feet behind the tops that is my number, do I need to add for the sub horn length difference?
4 20" T39(built)
2 WH8(built)
3 WH10(own)
4 DR200(own)
1 Jack 12(built)
SAC 24 Channel Mixer
SAW STUDIO Recording
guitarkeys.com
Re: Delay
You would be looking for a common denominator.
Jamie
Jamie
Jamie
Fayetteville, AR
Fayetteville, AR
Re: Delay
No. If you do that then the backline will lead the PA. Delays below 100Hz are very difficult to hear, if not impossible. Delays of even 1ms can be heard in the mids, so what's important is time align of the mid sources to each other.Haysus wrote:So if the back line is ten feet behind the tops that is my number, do I need to add for the sub horn length difference?
