I've been looking over the various offering of BFM Cabinets, and am thinking that they may be the right fit for a project i'm about to start.
I have the need to build a Concert Style PA system for an outdoor venue. There is a pavilion that has 3 walls around the stage area, but the audience area is open (other than the roof and support pillars). Stage is about 7ft off the ground, audience area is a long rectangle. The pavilion can hold 2,000 people, and to it's side is an open field for 'overflow'.
The dominant style of music that will be played at this venue ranges from some country to mostly classic rock. Maybe some newer rock / heavy metal thrown in the mix. In addition, the venue is also considering booking National B, C List bands.
QUESTION #1: I had made a post on PSW Forums - and got flamed for about 3 pages about the idea of using Custom Cabs, particularly BFM for this need.
With this in mind... I'm considering building Titan 48's and DR 300's. By my estimate, I'm 'guestimating' a quantity of 8 for each, totaling 16 cabinets between subs/mains. Due to the height of the stage, I'm unsure about how I would position the subwoofers (center cluster -vs- v-coupled) Stage is about 50ft wide, 7ft tall. The audience can be as close as 20ft from the front of the stage. The mains will be hard-mounted directly to the 12"x12" vertical support beams on the side of the stage going up to the roof. Was thinking 4 per side, in a vertical line array style, with the top speaker being against the horizontal support beam, and the other three cascading below it at a slight curve for optimal audience coverage. (BTW there is still about 10ft above the horizontal beam i'd be mounting to before you reach the actual roof)
QUESTION #2: Which subwoofer arrangement do you think would work best for this venue?
QUESTION #3: Given the size of the audience area, and lack of walls - do you think 8 mains and 8 subs is too much? not enough? just right?
QUESTION #3: Do you think the mounted line array style would be the best choice for the mains, given the possible close proximity of the audience, or would 4 per side stage stacking be a better suit for this? (Would still get the mains a pretty decent height above head level)
Looking forward to hearing from some of you that have real-world experience with BFM Cabinets. If you can shed any light on the overall SPL, quality of sound, etc, would be greatly appreciated as well
Thanks
P.S.: an interesting picture I found while Google'ing...
That's the interior of a EAW KF760...
Currently sells for $9,103 per cabinet from a well known retailer....
Anyone able to see why that cabinet should cost nearly $10,000 each!?
Another thing I noticed... someone had said on PSW that there was no way possible that the BFM DR300 with 1x12" and 2xCD's could compete with EAW 2x12 + 2x10 + 2CD's... in looking at the interior of the EAW - I noticed something odd... the 2x12"s that are loaded in the back aren't really a true 'horn load' by my understanding? notice that the horn sides run parallel to each other the full length of the back and sides of the cabinet, without any increase in horn size, and no flair at the end... use of 2x12" -vs- 1x12" is only a difference of 3dB not horn loaded... so why would it be 'impossible' for a properly horn loaded 1x12" to outperform a 2x12" that isn't?... just food for thought from a semi-noob
