Amp for THTLP
Jarko
Amp for THTLP
#1 Post by Jarko »
Hello,
I will be starting my build for THTLP soon, and I am looking for suggestions for a Rackmountable Amp for it. I would something that would be able to handle 2 subs.
Thanks
Re: Amp for THTLP
Reconsider, you want an amp w/built in low passing. There's no advantage to a rack mount, and you can put a plate amp into a case.
Jarko
Re: Amp for THTLP
#3 Post by Jarko »
Got it.
For a standard plate amp would the Bash 300 be sufficient for powering two? Only downside I see to that amp is that it's OOS at PE until Feb. Any other suggestions? Would the Bash 500 be overkill?
