How should driver testing "sound" ?
bean438
#1 Post by bean438 »
So I have my 15" Dayton hooked up and running 30hz @ 11.4 volts.
I can hear a bit of the sound, but more likely the vibration of the driver. If I stand directly over the driver I can hear more of a tone, but as i step away it is vibration only.
I can also hear a "flutter" type sound, like a butterfly.
There is no clanging, ticking, knocking etc.
Just wondering what i should be listening for if the driver was defective.
Thanks guys
Dave Non-Zero
Re: How should driver testing "sound" ?
#2 Post by Dave Non-Zero »
The flutter is probably air noise out the back vent of the magnet. Do you have the speaker hanging in free air or on a surface. I found propping the magnet up a bit stopped the air noise. I think a defective speaker sounds exactly that- defective. :) buzzing, rasping, etc are all bad signs. What you describe sounds normal.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
bean438
#3 Post by bean438 »
It was sitting on a concrete floor.
I propped one end on a block wood, and now the flutter is gone. There is still a "rumble" when I stand over it, but when I am 5 feet or so, or more away I can barely hear anything.
It sure is getting a workout. The cone is moving pretty fast, but not much travel.
#4 Post by Tom Smit »
And so all is good.
bean438
#5 Post by bean438 »
Does the break in have to be continuos?
I had to recharge my ipod, which has the test signal. Went about 6 hours, break for 2, and now back on over night.
I was surprised at how hot my stereo receiver got! On the back it says 4-16 ohms. I put a fan in front of it to keep things cool.
#6 Post by Tom Smit »
Yes, the time can be broken up;it's the total that counts.
Dave Non-Zero
#7 Post by Dave Non-Zero »
Sine wave is the most power intensive and demanding signal so it's asking the most from your amp longterm. Here are my lab 12 drivers breaking in at about 12v 30hz.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
#8 Post by AntonZ »
:loler:
Great vid, Dave, thanks for sharing. What a superb way to brighten up the otherwise most boring aspect of any sub build 8)
