I'm working on a t39 and was curious what is the best way to cut out the small tapered braces. I have a 10" table saw and of coarse a hand circular saw.
I have an adjustable taper jig I bought. but have never used one before. and I don't feel comfortable getting my fingers near the blade on the small braces.
I already cut them to the wide dimension and just need to put the taper on one side.
Any Ideals?
best way to cut tapered braces
T39 / OT12 Bass rig
2 T-48
4 DR250, 6 T-48 in the works
2 T-48
Re: best way to cut tapered braces
Make a panel jig.
Yep, sled is the only way to go.
Taper jig is good for table legs or such. Not so much for the braces.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
I used a pull out/extendable mitre saw/chop saw. Very easy to work with.
I'm in a time crunch so I just ripped a piece of 3/4 about 10' wide. cut out the braces to the wider end dimension. I Stacked the braces with double sided tape inbetween and drilled 2 pilot holes, Screwed them to the plywood and ran through the saw. Might not be the best method, but it was quick and accurate.
I work full time, In the final process of building my house, and many other projects too so I am spread thin.
T39 / OT12 Bass rig
2 T-48
2 T-48
+1 Exactly how I do it too. Quick, easy, and no time-consuming alignment. Especially for the longer ones.....mobetter wrote:I'm in a time crunch so I just ripped a piece of 3/4 about 10' wide. cut out the braces to the wider end dimension. I Stacked the braces with double sided tape inbetween and drilled 2 pilot holes, Screwed them to the plywood and ran through the saw. Might not be the best method, but it was quick and accurate.
While you're at it, do your cutouts while the pieces remain screwed together.
