Crown XLS Drivcore or XTI Series For Bass Amp
MusicalAlchemy
#1 Post by MusicalAlchemy »
I recently purchased an ADA MB-1 pre amp and am about to build a T39 loaded with a 3012LF on the bottom, and an OTop 12 loaded with a 3012HO and a full melded array on the top. These are the cabinets I was told to build when I asked the question on the forums when I had my SVT-IV, so I assume I would still want the same cabinets for bi-amping with a 6 string using the ADA. Which power amp would be the best for this setup, one of the XLS Drivecore Series or the XTI Series?
Thanks
sine143
Re: Crown XLS Drivcore or XTI Series For Bass Amp
#2 Post by sine143 »
xti 2k will do you. run -3 limiters, and hp your sub at 45 hz, crossover to tops between 125 the xls *will* work, but you wont be able to hp your sub, which means you could run into blown driver issues.
#3 Post by Chris_Allen »
Given the fairly flexible EQ on the ADA, I think the drivecore is more than good enough.
