My end goal is four dr250's with four or more T39's or 24's.
My current plan is to use the 800 on all four subs. I figure that will be about 200W per sub. Then for the tops I thought about running a 400 per side. The problem is though, that I'm going to end up with a 5 ohm load per side, and that would be a bit low to run the 400 bridged.
The specs are:
IPS 400- 200W per ch. @4 ohm or 400W bridged @ 8 ohm
IPS 800- 400W per ch. @4 ohm or 800W bridged @ 8 ohm
It just doesn't add up right in my mind.
I also want to BI-amp, my tops. Regardless of the reasons why that is a good or bad idea, I decided that I need to buy another amp, and that maybe the IPS250 would be good for the highs, or if i can find another 400 just run it with the gain turned way down.
I'm open to other amp options, but i got these for so cheap I doubt I could find something else for what I have into it now.
Thoughts?
