How Long Before Safe Gigging?
doncolga
#1 Post by doncolga »
Hey,
Once the second side is attached, how long before the sub can gigged with safely? I know PL fully cures in 24 hours, but I may be in a pinch....
Also, for the weather stripping around access panels, should I butt two ends together to form the corners or should they overlap a little?...I'm guessing butt the pieces but I'm concerned about leaks.
Thanks!
Donny
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
netwerks
Re: How Long Before Safe Gigging?
#2 Post by netwerks »
doncolga wrote:Hey,
Thanks!
Donny
Donny you are gonna want to check that cab for leaks inside and out before you run them with the access covers. I would be more concerned with leaks in the chamber and inside the cabinet from the last panel you installed. Check it good and fix any leaks with PL except for where the driver meets the baffle and for that part you can put some clear silcone.
http://www.hardwarestore.com/pop-print/ ... rodNo=8234
On a side note, on my last build I quit using speaker gasket to seal the access panel and just used a big bead of silicone instead. NO LEAKS.
#3 Post by Bill Fitzmaurice »
netwerks wrote:fix any leaks with PL except for where the driver meets the baffle and for that part you can put some clear silcone.
Silicone inside a cab delays the process, as it should be fully cured/degassed before sealing the cab, otherwise fumes could damage the driver. I use acrylic caulk if there's any leakage around the driver frame.
Greg Plouvier
#4 Post by Greg Plouvier »
netwerks wrote:On a side note, on my last build I quit using speaker gasket to seal the access panel and just used a big bead of silicone instead. NO LEAKS.
Well that will certainly seal the cover but if you ever need to get it off might be a bit of a problem.
Greg Plouvier
WB
#5 Post by WB »
Rat fur is the nicest access panel seal imo. Even the closed cell foam seems to want to glue a panel together if it's been together for a long while.
A little off topic but I thought I'd mention it.
netwerks
#6 Post by netwerks »
pops right out with a screwdriver and scrapes of easily for reapplication IF you ever need to open it.
