Page 1 of 3
				2 24" T48 build (my first build)
				Posted: Sun Aug 22, 2010 12:03 am
				by djeccentric
				Re: 2 24" T48 build (my first build)
				Posted: Sun Aug 22, 2010 12:31 am
				by Doug Hart
				lookin' good man... keep us posted
				Posted: Sun Aug 22, 2010 10:39 am
				by netwerks
				Looks just like a speaker to me! This means the fun part is about to begin!
				Posted: Mon Aug 23, 2010 12:55 am
				by djeccentric
				i have my first build question.  in the plans i don't see exact measurements for laying out the holes for the handles.  how are you guys laying them out?    sometimes it is just best to ask.  i plan to use a hole saw at each end and a jig saw to go between.
today i went through and sized all the 23" +- pannels.  when i was getting started today (after cutting on side yesterday) that i had not measured my plywood thickness which turns out to be 15/32  which i knew when i bought it but sort of forgot.  anyway i couldn't take much of a cut off the other side and them still be 23 1/16  so i made them 23 1/32.  no big deal just my box wont be 24" like i planed it will be 23 31/32"
				Posted: Mon Aug 23, 2010 1:11 am
				by sine143
				djeccentric wrote:i have my first build question.  in the plans i don't see exact measurements for laying out the holes for the handles.  how are you guys laying them out?    sometimes it is just best to ask.  i plan to use a hole saw at each end and a jig saw to go between.
uh oh, looks like someone forgot about the added width for corner hardware.  I suspect your box will be somewhere around 24 13/32 when you finish and put the corners on.
what I'm trying to say is:  as long as it fits, who cares how many 32nds you are off hahaha.
				Posted: Mon Aug 23, 2010 2:08 am
				by djeccentric
				sine143 wrote:djeccentric wrote:i have my first build question.  in the plans i don't see exact measurements for laying out the holes for the handles.  how are you guys laying them out?    sometimes it is just best to ask.  i plan to use a hole saw at each end and a jig saw to go between.
true but anyway.  i guess i know i made a mistake.
				Posted: Tue Aug 24, 2010 10:36 pm
				by djeccentric
				Posted: Wed Aug 25, 2010 10:52 pm
				by djeccentric
				well i did some more work today. made one major mistake. i cut panel 3 an 1/8th too short. (cutting angles are tricky.  anyway i decided to install it anyway. it caused a slight overhang of panel 4.  nothing a file wont fix when the glue dries.  hopefully it wont hurt performance.  anyway i am going to wait a lil while for the glue to set some and go back to it.
				Posted: Sat Aug 28, 2010 1:36 am
				by djeccentric
				i worked some tonight and last night. boy i am getting frustrated.  i feel like it is not coming out well.  things are pretty much all withing an 1/8th at the most/ most thing a 1/16 or better.  like i said i am a machinist so i am used to super tight tolerances.  i guess we will see when i get it done and weather or not it works well.
				Posted: Sat Aug 28, 2010 2:33 am
				by Charles Warwick
				All that matters is that it is sealed tight. Whenever I've got a loose joint I just put an extra bead of PL on and smear it up and down the line with my finger or a paper towel to make sure it is sealed. Even if you're off with the panel width as long as there is glue preventing the air from escaping there won't be any real performance problems since PL can fill 1/8 gaps easily.
Accept the fact that well braced and airtight is more important than looking good.
Isn't that someone's quote?
Just take it slowly, follow the plans carefully, and you'll get there eventually. My first build was a pair of Otops, and I really wish I would have taken them slower since I built both of them at the same time in a series of days. I failed to notice my mistakes gluing the first set of panels and ended up with most the panels slightly off, so my Otops are not square...
  But you can only tell if you put a square against it since I sanded them down to make it look square
Keep going!
				Posted: Sat Aug 28, 2010 9:48 pm
				by djeccentric
				Posted: Sun Aug 29, 2010 3:09 pm
				by el_ingeniero
				Looking very nice.  Don't worry too much about the insides.  If the cab is airtight and square, who's gonna know?
				Posted: Sun Aug 29, 2010 3:18 pm
				by ketoet
				looking nice
 . keep up the good work
				Posted: Mon Aug 30, 2010 1:16 am
				Charles Warwick wrote:All that matters is that it is sealed tight. Whenever I've got a loose joint I just put an extra bead of PL on and smear it up and down the line with my finger or a paper towel to make sure it is sealed. Even if you're off with the panel width as long as there is glue preventing the air from escaping there won't be any real performance problems since PL can fill 1/8 gaps easily.
+1
Charles Warwick wrote:Accept the fact that well braced and airtight is more important than looking good.
Yup. DJPhatman's
Charles Warwick wrote:Just take it slowly, follow the plans carefully, and you'll get there eventually.
+1
				Posted: Mon Aug 30, 2010 4:31 pm
				by el_ingeniero
				Tom Smit wrote:Charles Warwick wrote:All that matters is that it is sealed tight. Whenever I've got a loose joint I just put an extra bead of PL on and smear it up and down the line with my finger or a paper towel to make sure it is sealed. Even if you're off with the panel width as long as there is glue preventing the air from escaping there won't be any real performance problems since PL can fill 1/8 gaps easily.
+1
If the crack is really big, stuff extra wood into the crack, and glue liberally.
