Amp opinions
Trauma11
Amp opinions
#1 Post by Trauma11 »
I am building 4 tuba30s, 3012lf loaded, and 4 dr250s.
The plan right now is to run the tubas on a crown xls 2500 and the dr's on a crown xti 2000.
From what I've been told and researched this should be good but does anyone have any other suggestions? Maybe cheaper, but I don't want to sacrifice quality.
Thanks
Brett
sine143
Re: Amp opinions
#2 Post by sine143 »
why the xls2500 on sub duty? They can only run 1 filter per channel... which means you dont have the necessary hipass.
Re: Amp opinions
#3 Post by LelandCrooks »
Flip that. Run the subs on the xTI. You need the lowpass/highpass. The XlS doesn't have it.
Re: Amp opinions
#4 Post by Bruce Weldy »
Or, take money you save from buying XLS instead of XTI and buy a Driverack - it'll do all the crossovers plus EQ, feedback control, limiting, and more. There are options out there. Decide just what gear you will be using at the front of the signal chain before choosing amps.
Depending on your situation, you might be fine with a graphic EQ, and the high end amps that include limitiing and crossover. Or, you might be best off with a processor like the Driverack and cheaper amps that have the power, but not the processing. Also, if you already have EQ and a crossover, that changes things too.
The best advice for you can come after you let eveyone know what you already have and how you intend to use it.
Trauma11
Re: Amp opinions
#5 Post by Trauma11 »
Ok and the xls will be fine for the tops?
Re: Amp opinions
#6 Post by LelandCrooks »
Yes.
