http://archives.telex.com/archives/EV/S ... %20EDS.pdf
The horns in both cabs work fine.
One one cab it is not putting out anything on the woofer. So I would presume, it's toasted.
The other does not play sound at low volume, as you turn it up it starts to cut in and out and after you run quite a bit of power in, it will play but a bit distorted. I assume this woofer is on its way out. Also the longer it plays at high volume it also begins to cut in and out. I'm assuming heat related i don't know...Any idea what would be the root cause of this?
I originally thought it may be due to a dirty pot but i cleaned them, and then added another set of cabs to test and there was no problem on those cabs. (I don't want to take them apart just yet)
So now he's considering reconing the woofers or installing replacement woofers although I wouldn't begin to know what driver to replace them with.
Another alternative is to build a set of BFM cabs to replace them.
He's got a big old heavy Parasound HCA series amp http://www.parasound.com/vintage/hca1500a.php and since the cabs will be in his garage and never get moved. (ever)
I'm thinking a pair of Omni 15 full range tall boys
