Hey,
I got message from a supplier:
what I have in stock is a 10mm(13/32") 5 ply Parica which is similar to a Poplar. Very color consistant and light in weight. I also have a 13.2mm (17/32") 7 ply Faveira. This is probably more on the lines of what you are looking for. It is dense and heavy and would be ideal for speaker boxes.
Found this for Faveira:
http://www.libertywoods.com/faveira.html
Janka Hardness: 670 pounds
Strength (MOR): 9,717 psi
Stiffness (MOE): 1,670 1000 psi
Density (KG/m3): 470
Anyone familiar with those?
Thanks!
Donny
Parica and Faveira Plywood
Donny Collins
Two 18" Tuba 30's 3012 LF
Two 26" Tuba 30's Lab 12
Presonus Studio One DAW
Re: Parica and Faveira Plywood
Never mind...they normally only sell by the containerdoncolga wrote:Hey,
Thanks!
Donny
Donny Collins
