Amp for 4 tuba 60's?
Posted: Fri Jul 02, 2010 4:33 pm
by pyroibw
whats a good amp to use for 4 lab15 loaded tuba60's?
was going to use a xti4000 but that leaves no headroom. any suggestions?
Re: Amp for 4 tuba 60's?
Posted: Fri Jul 02, 2010 4:38 pm
by sine143
XTI 4000 is more than sufficient? 2 on each channel, prolly net you around 1100 watts on each channel (550 per driver... which is probably over the voltage limit).
Posted: Fri Jul 02, 2010 4:52 pm
by sine143
oopsie, 6 ohm drivers, so you get more power form the amp I'm not the mathematician I'd like to be.
What is the voltage limit on the T60 loaded with the lab 15?
